8 hours ago, Dmitry said:
Can anyone please share the catalog pages for the 1910 model? I wonder if the part is somewhat interchangeable, thus increasing my chances of finding it. If you know what that part is, even better, I wonder if there are other models that have that same wheel, but with the S37 size it is unlikely.
unfortunately 37 size watches usually have parts larger than other watches and the ability to interchange with anything in the universe is nonexistent almost probably. Then parts catalogs in 1948 was scanned in some incredibly high resolution with the incredibly huge file size which is why no one in their right mind is going to attach it to anything as huge PDFs clutter up the message board. To get anything that was it resembling readable I had to increase the file size and it still isn't the best and it is a rather huge file for just four pages. I think my copy was purchased off of eBay somebody probably had a disk of stuff.
Waltham Watch and Clock Material - 1948 Edition p40 43.pdf
13 hours ago, Neverenoughwatches said:
Repivotting is an option but you'll need the tools and a lathe
Actually, as the wheel is big, it is possible to repivot it without special tools. Just good hand drill needed and proper drill bit of the correct size, close to the pivot size. If needed, I will explain how and show some pictures.
On 10/1/2024 at 6:07 AM, Dmitry said:
...When I remove the pallet form and give it just a bit of a wind, the train spins nicely, even with just a bit of a touch to either of the two mainspring barrels - yep, it has two!...
Well, this statement brought all of us to delusion. It appears now that the train was blocked by the wheel with broken pivot
On 10/25/2024 at 2:58 AM, rjenkinsgb said:
There is a 1940 parts catalog  viewable via this page, though it's not downloadable and a real pain to read..
https://pocketwatchdatabase.com/reference/catalogs
I found an alternate link with direct access to each section, this is the Automobile & 8 day link:
https://pocketwatchdatabase.com/guide/company/waltham/catalogs/waltham-watch-co-material-catalog-1940/40
Part number 28172 found me a set of wheels on ebay! Now I wait for delivery and will update the forum once I plug in the new wheel.
On 10/25/2024 at 3:30 PM, rjenkinsgb said:
Does this have the same movement?
https://www.ebay.co.uk/itm/156300384066
I will try to buy this one if my wheel purchase does not work out. Escapement parts look good and it is indeed th same model - 1910.
The new wheel is in, but the watch still stops:( Before I touch the bankin pins, I will strip it once more and clean both barrels to make sure the springs are giving it all the power they can.
I haven't followed the discussion in detail, but I'm thinking that you must try to locate the source(s) of the problem. If the problem is that the barrels aren't clean enough that's what you need to do, but I would say that is the least likely source of your problem. Analyse the watch in function groups as show by Kalle Slaap.
Triumph! As many have suggested escapement was the culprit. Despite the pictures looking good, I started to examine each piece independently and when each piece worked separately, I finally got a closer look at the balance wheel and touched the impulse jewel. Although it looked right, it wobbled on me.
I have since shellacked it in place and the watch is running nicely again!
Thank you for all your help. Lesson learned - examine typical suspsects first and up close.
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
