28 minutes ago, AndyGSi said:
Difficult to tell from the photo how bad the head is but this is the official screwdriver for that particular screw.
Edit
As a fix you may have to use a 0.8mm flat blade and put a chamfer on either side so the tip is then about 0.4mm
Thanks for the quick reply. The picture says 1.2mm. That seems way too big. I’ll try filing down my cheap .8 to see how that works.
