In Absentia
Very nice but like George says it's tidy. Now I don't mind admitting my old work bench had stuff all over the place in fact it was absolutely filthy, people would come into my work shop and remark how untidy I used to be, my answer to them was I new where everything was.
I thought the rules said that everything on the desk had to be covered with horological paraphanalia and bits and bobs generally except of course about a square foot in the middle reserved for actual working.  Natty electric blue loupe though - want one.   like our Bob says, you could have put a watch on the desk though instead of that digital clock (which incidentally will be a constant reminder that there are other jobs in the house to do instead of hobbying).  Don't know what bike that is but I bet George has one.
Seriously, good that you are back and hope the sorting out gets completed without too much strife.
Vic
    • Hmmm you know when i said some damp might have caused the bubble originally hmmm.
    • Are you all jerking my chain, I'm a yorkshireman £4.04 is too much 😆
    • [Myota2034] Custom simple quartz watch — PricewaterhouseCoopers On a very very different note, here is a watch from approximately 2000 when I was a Partner with PwC, Management Consulting. It was a simple “marketing watch” with a clever “vase of knowledge” that is subtly revealed on the dial as the second hand progresses. Clever for a simple watch!⌚️
    • I think someone else has though. Some where here using a modified perspex sheet. I may be wrong i may be right , i think it involved fitting the arbor to a pin vice. I dont have experience of the bergeon winders, are the handles not interchangeable ?
    • Never tried dial dots, i always considered them as a bit of a bodge.  You are adding something that was never intended to be there. I wonder how the adhesive reacts to any part of the movement, hot summer heat and i think things might turn sticky. Most adhesive backed stuff has a tendency to soften and slide around so it may spread, i have used a lot of so called sticks all adhesives in my industry that are just not up to the job. I suppose they get you out of a problem quickly, but how permanently might that be ? I would just explain to the owner that it may or may not work. WWs other ideas are a much more permanent solution but both have their risks . I've tried milling and dial feet replacements, hmm it was ok, ive heard of folk dimpling the face , so that needs care . And i have soldered a few times , all with good results but i am very careful and I practiced it a lot.
