Hi There...anyone got a parts diagram for a Tag Heuer 7T32B...Need one urgently as I have a part that I cannot find where it goes...Please
Is this right? I thought a 7T32 is a Seiko (Hattori) chronograph movement.
It sure is, and it's the trickiest movement I have ever worked on. The gears were like sequins and there are about twenty of then!
Hi There...Do you know if any parts diagrams are available for this movement. This watch was stripped by someone and then handed to me to assemble and there is only one tiny part that I cannot find a place for it. Have you worked on the Tag SQ4820 ? Maybe if I mail you a photograph of the part you may be able to identify its home on the movement.
What is the part that you can't fit to the watch, can you take a picture let us see?
Is this a replica TAG with an automatic ETA movement? If it is is there a calibre number in the area of the balance?
I am afraid I don't have a cross reference to know which movement Tag uses in various different models. But looking at a picture of this watch it has sub dials at top, bottom and left. This is indicative of a Valjoux 7750 movement. If you could post a picture of the inside then we could confirm this.
If it is a 7750 then the data sheets are available on the ETA website, or cousins. And I even have a strip down on my YT channel.
There is no number at all on the movement except on the back of the watch. I will try and take a photograph of the part and post it. Thanks for all the help to date.
It would be most helpful if you could post a pic of the actual movement as well as the part you have posted. :)
Hi There,
I have attached a photograph of the partially stripped movement. The part in question does go somewhere in this area of the stripped movement. Thanks for the help.
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
