Omega Speedmaster Mark Ii.....
Aloha all ,
  I was at work Friday morning and I stopped in the convience store to get a cup of coffee .  The superintendent of the job
also came in to get some coffee ,....and being the WIS that I am , asked him what kind of watch he was wearing . I told him that I collected watches , and he said that a colleague of his also collected watches and gave him the Bulova he was wearing .
 He brought the fellow to meet me and he said He had an old chunky Omega in a drawer at home that he bought new 40 years ago and asked if I would be interested in it , .....you know my answer .  He brought in this Omega Speedmaster Mark II from around 1969 ,'70 .  Everything works as it should .
I picked it up for $200......
I was quite pleased when he showed it to me , and quite surprised when I got home and did some research .
  At first he suggested $100 , or maybe just give it to me ..... that was on Friday .  Today , Monday , he said after looking at it again , he'd like $200 maybe , but give him what I thought I should . I told him that he had offered it for $100 , now $200 , ....so would he accept $175 . He agreed and I went to an ATM to get the cash , then I thought to myself , "don't get greedy or nit-picky over $25 " , so I gave him the $200 . Which seemed to please him because I wasn't being cheap about the matter .
I forgot what the deep sea diver symbol inside the caseback meant . Compression case or Bovet ??  Can someone refresh my memory ?..... Thanks , Louis
    • My overall preference is to use traditional names and terms, that became my habit when i was taught joinery by old boy chippies 2 generations older than me , that had their time in the 40's. But what i often do is adjust the names and terms i use according to who I'm talking with. Sometimes i will say trainside and occasionally watchmaker's side. I try to find a balance between accommodating other folk ( there's no point speaking a foreign language to someone who doesn't understand it ) and using a name that appears to me to be more relevant as to its use or description. But using the name lever can be quite confusing,  some watches might have parts that are also levers, release levers, which in effect is what the pallet fork is, an escapement release lever.
    • Then put the case number in here https://www.cousinsuk.com/category/filter/search-seiko-case-parts and it should give you the crown
    • I come across to replace the crystal of a 7734 chronograph.  What make it special there a printed chapter ring  which fits inside the recess of crystal before inserting into the case. I am thinking of a high dome crystal such as Sternkreuz ATCH, fitting diameter OD332/ID320.  For this purpose, tension ring will be removed and fit in the chapter ring.  I understand the crystal size may not perfectly fit these two dimension.  Should aim to find the right ID, then OD can be grinded to reduce without much difficulty.  To find the right crystal, the easiest way is to get know of the OD/ID relationship of Sternkreuz ATCH/ATCG (otherwise the OD of the crystal and tension ring).  I hope you are able to help to minimize the trial and errors.
    • The case number should be on the back.
    • I agree, I call it a pallet fork for two reasons, it was the name used when I started watch repair both in written documents and on videos and calling it a lever causes confusion as seen.  Plenty of other examples where there's more than one name. What do you call the opposite side of the movement from the dial side?  I've heard you call it the watch makers side.
