Kundo - anniversary clock; suspension spring
Hello dear friends,
I just bought old Kundo watch... but it is super fast. I need to change suspension spring. Does somebody knows which dimensions I need? Watch is tall almost 30cm (11.8").
Dimensions of the spring mounted on the watch are - 126mm (4.96") x 14mm (0.055") x 0,08mm (0.0032").  Since the spring is bent, I'm not sure if these are the correct dimensions. It was measured with a ruler. On the Internet I find several different dimensions of springs for Kundo watches. Can you please help me and say which of these springs would be suitable for my watch? Pictures are from German watchparts seller. He said that they are original for Kundo anniversary clocks. They have marks 1, 3A, 3B, and 3C. I'm planning to buy just a longer spring and try to make the whole thing by myself, but I need correct measures.
Is the fork on the existing spring properly mounted? Isn't she facing the wrong way - upside down?
Thank you very much!
I just realized that my question is in wrong section... Can I ask the moderator to transfer it to right section? I'm searching option to delete it or transfer, but I can't find it.
Sorry.
BR
The suspension spring is wrong it should be dead straight with no twists or turns.. The strength of the spring is critical to strong or too weak and you will run out of adjustment. If can supply with the measurements of the movements back plate I can refer to my
“Horolovar 400 day clock repair guide” book to give the exact spring you need..
Hi Gabriel,
First of all, You need to undrestand if the existing spring is correct or not. To do it, You will need to untwist it. In such twisted condition, the pendulim will oscillate much faster. Untwisting is possible, but it will be hard to bring the shape back to ideal. No mater, the pendulum will oscillate normally as if the spring is not twisted. You need to turn the pendulum in untwisting direction several turns thus twisting the spring in the other direction, then check what has hapenned and if more turning the pendulum is needed to improve the spring.  As the spring will not untwist evenly, concentrate on it's upper part to untwist correctly. When it is done, grasp with tweezers under the rectified part and continue till all the lenght is done.
Then You need to understand what is the needed period of the pendulum oscillations. I have seen 20, 15, 12 and 10 sec. Observe the minute hand while moving the fork left-right manually, see how many moves atre needed for the hand to shift 5 or 10 min ahead, then divide this to the moves counted. After knowing the period needed, You can use timer to measure the real period when the clock is working and thus You will know fast if the period can be regulated to the needed value or not, and if the spring needs to be replaced. Thinning the spring is possible to slow the clock down instead of replacing it.
On 5/23/2024 at 11:02 AM, nevenbekriev said:
Hi Gabriel,
Hi! Thank you! That's great advice! I didn't know that this is possible. I will try it today after work and see if everything will be OK.
Thank you for help. From the pictures that you have posted, it seems that Plate 1407B have the same holes... Brand logo is on the different place... But holes seems to be in the right places. So, needed spring are 3A, 3B and 3C. From german seller, those models are the same lenght (126mm) but different fork height (14, 14.6, 14.8). Which one would be better? Iz such a small dimension important?
I restore torsion clocks and quite a few of the early ones there is nothing in the book so I lower the fork until it flutters ( drops more than one tooth at a time ) then raise the fork by 1mm, the book is only a starting position sometimes it’s ok other times not , every clock seems to be different.
everything is important with regards to torsion clocks .
Dell
Guys, thanks for your help!
According to the advice of a colleague @nevenbekriev, I managed to straighten the spring. Surprisingly, it turned out completely flat. Like new. And the watch after that, for the first time since it was with me, started running late. 🙂 That's great news!!! The rotation of the weights is about 190/200 degrees. In the past 12 hours, it was 4 minutes late. I still have enough room to speed it up. Looks like everything will be OK.
Thank you very much for your help!
    • Hi @nevenbekriev, I'm thinking of replacing the whole platform. Mine is marked 4-82. The seller has 4-69, 4-71 and 4-72. Will any of them fit my clock?
    • What you are showing most of it is missing. Just looked on ebay this is the best machine I ever had. I have had a few machines in my time. https://www.ebay.co.uk/itm/285902116112?itmmeta=01J0EW3685DS3DXFT0YK1M6CRW&hash=item4291181510:g:eRgAAOSwKBpmZsMW&itmprp=enc%3AAQAJAAAA0KMFnc%2BwDg6kFufauQZxMmo%2FXMOZUb8B8ZtxalJPVcGZYl0sjSXjgIHEyZ0dvGY57wsEJupTrvZkGyRH5A8KGf8GYSzSXE1F8VMaR5oJYP%2FgVmvU5QSidrbXULj3h1iqvptGXGVfko2HM%2BWKK5XSOE9Ek1FPwkVOi9p%2FbmX7FAp7Cr0GbUjAovPOI1QZdyc7ChZLNJiGQAsjfz4FzJAz8mvLKL2xwXGtbmhYf4l0BU7gQRLQ%2BHfKogEt5AO3xlR2F6fZxjNi5iB3W4RY7n7HniE%3D|tkp%3ABk9SR5bkjNyDZA There is also this one.  https://www.ebay.co.uk/itm/176424434347?itmmeta=01J0EW3685CBSTMC6HZCD24VJA&hash=item2913b73aab:g:WcIAAOSwm-ZmS3vn&itmprp=enc%3AAQAJAAAA0G7k%2FSuYiX%2Fhn1xO9kSpOZnqO525%2FC29sG7K0LRkRyzClvecttiEGFWe4ZOrXR42I6LCP9RSWPjnOdr3wzuhofuIAI%2FUhHq2VwPDTLpy5M%2FATDlCvUueqPlNL9%2FXBOJx8HpxavHbrw%2Bz3%2FW9YOil2nq5U%2BRfu10yBilLrFeJeCi8kZL6gcrIOnReTuh1tO%2F4XG0uVDr0Y9Vze27CMKpR2cb8I%2Fqyt%2FHVXS2tMu7x%2FJTfOTzw85wzUpt5WeVLCcV7MKpGytwVesyPs9t4g05KWLk%3D|tkp%3ABk9SR5LkjNyDZA Another  https://www.ebay.co.uk/itm/196429850292?itmmeta=01J0EW3686SKPN1WSF129KR20N&hash=item2dbc21a6b4:g:~7kAAOSw41pmYXfG&itmprp=enc%3AAQAJAAAA8Cj5grIbnKC5SFi%2B0%2B83GgokdKXHur9QvJ%2FKnte%2FDar5L9PoB%2BFs%2BcOti9BkDgCd7r9vBSG%2BINHCtprmUtKJC%2BA%2BPKBEQbgYVt3mp3VVi%2Bk4sX6%2BlrwoSZD5wW8btH8YRQbvBTo1y%2BfAZWhBN7dBbOncVlsDPeIQnxhoX27onRA0cOkqJwaB95xhK9lIUZ1qHeMb8J58cmLfmy4dt7HuQOMQ%2BIJCz9Yd96Kw1SyprG90yB2wCUd4dshpzK0z1cSX7dvHPy7ZTn1GJL2Zs%2B1j630ZPwEeSwTsxDtKUuLTyPx20SE37XD%2Fllg2llakO7AH7g%3D%3D|tkp%3ABk9SR5jkjNyDZA More https://www.ebay.co.uk/itm/176410156286?itmmeta=01J0EW3686RHQ5CNHDSSZ17QW0&hash=item2912dd5cfe:g:nJIAAOSwnztmYEVF&itmprp=enc%3AAQAJAAAA0I56oof2IHqmGAwUUoqpoIM971obYtQeElg%2B7X8PL9CG7PXDtCKgovcgq7uu5OcLTmZRDSf3qiSuZUxZKafLo08I4OHEYDa3uMi4jKcAYZJq2M3kDK3utnODNLx9VN0swZqGi7KVdVzrAMV7V4UCF7eUBpAYJizdbSyxbnCgnAStxQEdBuBroTbPzj6%2B79HetBmFknueT9%2BfLRePi6y0LMN0VsDG3yEstvRHKW%2BlC5LNWgWnweQwAy8qDPKW9lfFRnI%2FDzLbLI3yCPT3NClmGYQ%3D|tkp%3ABk9SR5jkjNyDZA Make sure it comes with the jars and basket. Members on here have restored some dilapidated machines and the look like new.
    • Just in case You didn't notice this: The jewej is broken and no wonder, the decision of the movement designer is a little strange here.
    • Well I've gone ahead & used an epoxy resin - applied with an oiler - on the missing rivet holes to see if that stabilises the loose metal piece which incorporates the ÷ve battery connection. So far it seems to have done the trick  - my wife has dropped it on the table attempting to put it on & worn it overnight & it's carried without missing a beat.
    • Hello everyone, this will be my first proper walkthrough and also my most complicated watch yet. A beautiful JLC Memovox E875 ("Speed beat") with calibre 916. This is the first of several posts: disassembly. You'll see my order of disassembly and close-ups of all the screws. Those are the main points. If there's anything particular, I'll write a comment. Otherwise the pictures are hopefully self-explanatory.   Here's the beauty before disassembly:   Ready to go with nicely dressed tweezers... also, screw slots are generally very thin so I also dressed all screwdrivers to very fine tips.       inside of the caseback has a little knob that is hit by a hammer to create the alarm sound. Movement complete. before any disassembly, you can already see the magic level system of the automatic works I start by taking off the rotor. rotor underside rest of automatic works with three blued screws. magic lever system balance first.. identical stems.    two case screws     retention ring holds the gasket   hands off and some dial-porn   dial feet screws are nicely positioned so you can hold the movement in one position and access both at the same time. Thanks, JLC!   both dials off   let power down before this point!   driving wheel for ratchet wheel / kinda-reversing wheel   the alarm system       train bridge   I take the opportunity to remove the clutch wheelS and sliding pinionS. Again, both are identical. Nice.   back to the train barrel can come out without damaging the center wheel. But careful.  underside of the bridge with TWO crown wheels. NOTE: one "seat" is missing. Its absence has cause some damage to the bridge. I had indeed felt some resistance when winding the alarm barrel and it was one reason why I wanted to service it.. Part 414 is ordered from eBay.      Barrel says "do not open". A whole other thread is devoted to this, see here:         let's do the dial side:   this spring was hard to get out. only an oiler would squeeze under it. the date wheel can stay assembled like this (no disassembly shown in the manual) previous watchmaker liked oil a lot. the alarm activation wheels lots of wheels..   also part of the alarm system   pretty cool how the two keyless works are kind of the same and with some overarching parts damn, this spring was hard to get out. canon pinon and then the center wheel i remove balance jewels on both sides for thorough cleaning and reinstall the balance for cleaning.               alarm barrel is normal (no "do not open").   the main barrel takes some nerves to open, but does so just fine. However, the edge of the barrel (where it holds the lid) is burnished a bit. I'm smoothing it out with the pointy end of a bracelet tool. This will allow the lid to go back in without problems. I'm planning on burnishing it over again when the new mainspring is installed. work in progres. done
