I've been contemplating getting one of these for some time now, after working on a few spring loaded centre seconds pinion movements. It's not an absolutely necessary tool to have, hence the procrastination.
Then it hit me, all I need is a flat base with a screw in it. So I scrounged around for something suitable and ended up with this.
This is some rubber thingy that is  supposed to stop furniture with casters from moving around. In fact, any flat material with sufficient thickness to hold the screw in the centre would do.
Maybe you should make friends with someone who has a 3D printer
1 hour ago, Malocchio said:
If the parts from China cost 5 cents and someone in Switzerland gets paid 6 cents for putting it together it can be called Swiss Made, right?
Something along those lines yes. So are you implying HectorLooi is a Swiss spy working for Bergeon to see what crap they can get away with selling us ?
22 minutes ago, HectorLooi said:
You need to write Bergeon on it.
could start a new sub-brand: Bergeon-Pro
Worked for Apple phones!
Ah they already beat me to it:
Or, if you have a staking set or jewelling too, just use one of the stumps. You can choose a fine tip to fit inside a jewel if necessary.
I've seen these , being a tool junkie, and thought that I could do with one. I can make one those as shown by you. I can make the holes and cutting easily enough so it would look like the original.
I only have one question please. How do you use it? I can find no-one on the internet who shows how to use the tool.
Ta
That Bergeon Premium Rodico is crap. I regret buying the stuff.
I have some Bergeon tools, and they are very good. When I need a quality tool, I don't mind spending money on it. But some people think the sun shines out of their whatsit, and they can do no wrong.  Sometimes you don't need to spend £££ just because it says Bergeon. My usual example, dial holder, a bit of plastic with holes in :
Cousins version £6
Begeon version £56 🤣
Ta
I'm interesting in seeing how you would use one too, and not use a staking set stump?
The movement is placed on the base and the centre screw is raised until it contacts and supports the centre pinion, thus stopping the centre pinion from sinking in when the second hand is pressed on.
Exactly!
It may not really be a joke, but the actual truth.
That all? Plastic pill top, small screw through centre. Made.
I assume you mean the bridge where the centre seconds pivot sits?
If so, the pivot may sit slightly below the bridge surface, especially if in a jewel. In which case you need a more pointed tool which actually sits on the end of the pivot.  Hence my post above about using jewelling/staking stumps.
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
