Case Opener
chadders1966
Hi everyone
If you've seen my previous threads on the subject of the LG wrench you'll know I'm looking for a good quality case opener. I did some time ago briefly consider buying one of the Chinese copy 5700s, but decided after taking Mark's advice it would be money down the drain. I have been looking for a used Bergeon 5700 or similar (I like the LEM (?) that Geo showed) and have been looking at the following listing from Ebay France, number 351469560721. Does anyone have any views on this item? I can see that parts of the head are missing, and also thought the printing on it looked a bit odd. Even though this costs a lot less than a new one, it is still a fair amount of money to spend. Thanks
Stephen
I have an LG watch wrench, I have always found it to be a good quality tool which has never yet let me down. Looking at the damage on yours it is hard to see how that even happened, the metal casting must just have been fractured from new for it to have broken from hand force. I have used a lot of force on mine at times to remove some pretty stubborn watch backs including ones that appear to have been glued on after I removed them. You must just have just been unlucky to get a defective one. I would imagine one or two others here have an LG wrench amongst their tool sets that have given them no issues?
I don't feel in any particular way about their products. I know that they are well regarded, and I was happy to give them a chance to put things right as mistakes do happen. The fact that they took 6 weeks to report back and then tried to blame the customer for what must be a material or manufacture problem is what concerns me, and why I would not want to buy any of their products again. The fact that Cousins completely ignored the companies 'findings' and gave me a full refund indicates what they thought of this as well.
If there is anybody who is familiar with the Bergeon 5700 I would be grateful if they could have a look at the listing I mentioned in my first post, 351469560721 on EBay France. I am considering this but am concerned with two issues:
1. Is it the genuine article? I have no definite reason to doubt this, but as I mentioned the printing on the head doesn't look very professional;
2. Also on the head the two thumbscrews (?is that even the right word?) that control the upper jaws are missing. Is it still in working order?
Any help/advice would be appreciated as it would be quite an investment for me. Thanks
Stephen
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
