Pcket watch "Art déco"?
Hi all of you,
I've just received a pocket watch without any brand name wich looks quite old, and the only information I could see on the movement is 7020. I haven't disassembled it yet, and I must admit I am a bit reluctant to do it as it seems old (but it works well).
Could anyone help me? Here are some photos.
Lovely dial. 15 jewels and Breguet overcoil on the hairspring. Have you got a pic showing all the movement, i.e. looking from the crown?
I've no idea what the movement is, it will be easier to ID once out of the case and measured.
Might be able to identify it once the diameter is given and a photo of the keyless works but no guarantee.
Ancre-----Lever escapement
Levees visibles---visible (jeweled)pallets
Double Plateau-----double roller
Spirale Breguet--Overcoil hairspring
Balancier compense----Compensated balance wheel
15 rubis---15jewels
Looks to be in good condition, and fairly modern.  I've never seen a bent regulator arm like that. Also the click is in an odd position. Should make identifying easier.
I found a comment suggesting that Cortebert are known for curved regulators
Edited by mikepilk
4 hours ago, BlueHarp said:
@mikepilkThank you for your reply. Here is another picture.
This is more complex than a standard pocket watch owing to fact it has 2 driving springs. A mainspring and a smaller spring that acts directly on the escapement. This direct spring provides a more constant torque helping to maintain isochronism and doesn't suffer the energy differences that a mainspring does delivering power through the gear train. The mainspring keeps the escapement driving spring wound up.
5 hours ago, BlueHarp said:
Hi all of you,
I have one very similar to this, i wouldn't disassemble it until you are ready to.
Rich, this one seems rather regular movement to me. Yes, what You describe exists, but I doubt that the one on the picture is something similar.
I'm with @nevenbekriev Rich, it just looks a normal movement to me .... unless you know differently.
Do you have pics of yours? Who is the manufacturer?
It seems this topic is becoming very interesting 😀. Here are two more pictures that might help to identify the movement.
The diameter of the dial side is 40mm, and the other side 36,5mm.
16 hours ago, mikepilk said:
I just broke my Rule #1 - Do not buy a watch unless you can see a good pic of the movement.
I currently don't have anything to work on (itchy fingers) and as I just got this for £20 from ebay, (sold as "working"), I thought it was worth the gamble.
I liked the look of it, It has 21 jewels, so I'm assuming automatic. The back says "Incabloc" and "waterproof", so it looks to be reasonable quality. The case looks good.
From the little I've found on google, the Credos Lugran company was formed in 1954., and bought by Bucherer in the 60s. This looks 50s-60s to me. There's a reference to using good quality ETA movements. I hope so.
7 minutes ago, Neverenoughwatches said:
I thought i read Remontoire inside the case ?
If it has a e on the end, Remontoire then yes two springs, without the e, stem wound.
Ah i didn't notice that but it was past one i  the morning when read it
The keyless works used for identification are hidden under the watchmakers side. You would have to disassemble it, you dont need to worry so much about that, doubtful it is a Remontoire as i suggested earlier this morning 🤦‍♂️ but you never know 😁
I recall a video on YT from Steffen Pahlow where he talks about getting himself a Chronometre (for which he paid more than he would have liked), but in his words "I had to. It is a Chronometre."
I am wondering if you have more watch there than what you are aware of? Especially with what @Neverenoughwatches mentioned about two springs.
That's true. It is not a chronometer. As a matter of fact, I got it with another timepiece which is e real one, and only that (not a watch).
I add a few pictures of my Chronometer / watch. no indication of a brand ...
11 minutes ago, RichardHarris123 said:
I'm not convinced it is a chronometer, just because it says so on the dial.  I think the two springs was a misunderstanding.
The chronometer on the dial might just be a brand name, looking back yes i was mislead by the mention of Remontoir inside the case. Still not sure why it says Ancre Remontoir which translates to anchor winder, i imagine that means lever winder which still suggests to me 2 winding springs. I'm sure i have that same watch with chronometer on the dial ,I've never ventured inside it. My missus looks after 90% of my watches , so i will get hold of that one and have a look inside.
Haha no not a remontoire, looks very basic.  Good to see the keyless works, can you measure the plate size to cut down on the search for them.
Can you lay out that brass bridge cover as well please next to the other 3 pieces.
Ok thanks  it was just the brass cover next to the previous 3 keyless parts. Normally i wouldn't have expected that to be used to identify,  but I've searched American,  German and French part catalogs and coming up with nothing for the set lever,set spring and  yoke. I will have another look later today.
There is another way but you would have to measure the stem very accurately.
35 minutes ago, BlueHarp said:
Ok. >Here is the picture
Its ok blueharp the pictures you provided earlier of the 3 keyless components,  the setting lever, the setting lever spring and the yoke plus the brass cover plate should be enough. If they are not listed anywhere then you are relying on any lettering on the movement or someone that just knows the movement from experience.
I've started trying to use the Betfit, but I don't know which measurement I must take for the caliber. The diameter of the dial side is 40mm, and the other side 36,5mm 🤔.
Here's a size chart. 40mm is about 17¾L. I looked in Bestfit but couldn't find anything close.
    • I’ve tried everything using both my blue and donut demag units.  I’ve even tried beating them with a steel hammer 🙂   im now trying heating them over gas flame — if that doesn’t work …..
    • The 110v supply could be problem with the blue one. Have you tried moving the piece to demag through different orientations manually as its drawn away ? As Nev quoted the magnetic fields of the demag have to overcome those of the steel.
    • Thank you Marc! I re ran the TG. First I went ahead and checked the balance jewel on the regulator and it was bone dry. I cleaned and oiled it, not without some drama including pinging the capstone and searching my bench with a black light for 30 minutes and finally shone it on my face and looked in the mirror only to find it on my left cheek in my 2 day growth! Back in and on the Grapher we are at 275. However significant drop in DD (234) and CR (190 edited) positions tells me it's time for a complete cleaning and oiling.
    • My $12 blue one seems to work well enough for movements out of case. However for  tools with greater mass, such as my small and large anvils which are highly magnetized the blue unit is useless.   For whatever reason, my high current K&D donut unit just doesn’t seem to work, regardless of my attempts to use it as instructed in this thread (magnetizes stuff fine so I know it is energized).
    • PUW1563 is the day/date version of the 1561 (date only). I have just measured a 1561 using the old "blob of paint on the rim" technique to determine the actual amplitude by observation, and then putting it on my TG and adjusting the TG lift angle until the displayed amplitude matches the observed amplitude. I get 48°. Not a million miles away but it will have overstated the amplitude by about 20° with the TG set to 52° (I tried that as well for completeness). So with a more appropriate lift angle set on your TG you would have got an amplitude reading of about 240°.
