DIY Screw polisher.
Inspired by Alex Hamilton, I have made my own screw head polisher. Less than £4 in parts. I hour to make. Chuffed.
Additional photograph information
Bottom nuts are tightened to make a solid base.  Nuts below and above wood are to make the level set when using the polishing base. I will get a small picture frame with glass to insert the polishing paper. The screws can be altered to accommodate. I can now polish to 1 micron.
I piece of wood 2" x 2 1/4". 2 x M4-30mm bolts. 6 nuts. 1 pin vice from set of 4.
Edited by rossjackson01
More information
  • Like 12
2 hours ago, mikepilk said:
Nice work Ross, but is it solid enough to work properly
Well, first screw would be cosmonaut 😛, but please mike don't tell Ross I said that.
 .... we await the first test.
Wise idea.
  • Haha 2
Have a look
Watches Repair Grinding tools for repairing watches Polishing screws watch clip large steel wheel - AliExpress
https://www.aliexpress.com/item/1005006323971307.html?spm=a2g0o.productlist.main.1.222eNcXxNcXx7O&algo_pvid=9dbf666f-da7d-478b-aeec-3ccf26ccc021&algo_exp_id=9dbf666f-da7d-478b-aeec-3ccf26ccc021-0&pdp_npi=4%40dis!GBP!34.06!28.95!!!303.26!257.77!%402103890917122601452468668eed45!12000037037463356!sea!UK!4431570049!&curPageLogUid=Ap2YMIcipYZ9&utparam-url=scene%3Asearch|query_from%3A
Click where is says . Colour tool board right image.  Full set of tools, for this item
This is £132 plus 20% VAT  plus postage  = £170.
Has ten different pin vice holders. Mine holds any size of Watch screw
Charging £28 plus Vat plus delivery = $40  just for the paper holder
Mine works well. Very solid
Spelling, Grammar, more information
…the first screw would be a beeping toaster that causes panic in the United States, then a dog screw, then the cosmonaut…
  • Confused 1
23 hours ago, mikepilk said:
Nice work Ross, but is it solid enough to work properly  .... we await the first test.
I have some brass bar left over, I might have a go at one myself.
Yes it is solid. Polishes the screw head well. I am going to attach a flat head (DIY) stump from my staking set into the pin vice, using a larger hole chuck. As Alex's comment, I can then hold any flat item with shellac so that it can be black polished. Not tried that yet, but should be easily possible.
Ross, I have had the idea of getting some dial feet replacements, the ones for the milling tool and supergluing them to small flat parts and fitting them to the tripod for polishing. Then drop them in some acetone (nail varnish remover) to get them apart once the part is polished.
Tom
Tom
Good idea for small items. Alex uses the stump for larger objects. Same principle with shellac though.
I couldn't resist Ross, and have started hacking some brass I have left over from the balance holder. Construction is under way !
What lapping paper do you use ?  Alex uses 6, 3, 1, and 0.5 micron.
Cousins don't have 6 micron, but they have 5 (4500 grit). I have 3000 grit wet and dry, so I'm wondering if I could go from that to 3 micron, 1 micron, and 0.5 micron (is this final one really necessary ?)
I need to find some glass
The hardest thing was finding the parts I knew I wanted, but had no idea what they are called. I found them eventually
Edited by mikepilk
I finished my polisher yesterday, and just tried it out. I'm surprised how easy it is to get a good result - just a couple of minutes. I thought it was going to be more difficult - a nice surprise as most things in watchmaking are harder than you expect.
I bought self adhesive 3M lapping film https://www.cousinsuk.com/product/film-lapping-3m-261x266x , 9, 3 and 1 micron, and stuck it to sheets of glass. The 9 micron is course enough to remove large scratches.
I'm glad I used the M6 thumb screws as the large heads allow for small adjustments.
Edited by mikepilk
  • Like 5
Getting more interesting this post, innit?
Mikeplilk, Waggy. Impressed with your efforts. Makes mine look amateurish. Hey, that's what I am. Still, I have good results with the 'frog'. Apprentice test piece.
Paper is from
https://www.ebay.co.uk/itm/234602659940?var=534248554534
I am aware that the more I delve into the DIY, the more I am gaining understanding of watchmaking. Well, a little each time.
Ross
    • @JohnR725 has pointed out many times that the Swiss don't care about amplitude, the timekeeping is the most important.  Give yourself a  pat on the back, great beat error and timekeeping, nothing to be disappointed about.
    • I'm bothered but I agree he's a busy man and I don't want to bother him.  In the meantime, we really do need to have other ways of contacting each other
    • This is as complicated as epilame, too many unknowns. The life expectancy in the UK is circa 80, so most people from 1944 or earlier are dead.  Assume they had children at circa 20, they died in 2004. Their children started selling 1944 watches in 2004, so pre-1944 watches must be getting more rare.   It doesn't work though because as you stated some were sold as tat, but since watch prices have increased people have decided to sell when they may not of done in the past.
    • I was wondering whether anyone could assist with some questions I have about my latest acquisition, which is a two train ‘Bravingtons Renown’ mantel clock - Pics attached I have done some reading about Bravingtons and believe they sourced movements from various suppliers, so I wondered whether anyone recognises this one. I have stripped and cleaned the movement and the clock is now running well, but there are a couple of dodgy brass springs that I would like to replace. I haven’t found anything suitable searching the internet so I wondered does anyone know of a supplier that might help. Last question is about the veneer on the case, it is generally in reasonable condition but there are a couple of patches on the top where the veneer has lifted. So far, I have tried to reactivate the existing adhesive by heating from below and above with a hair drier, then clamping for a day or two. It has improved slightly but the bulge is still visible. I’d be grateful for any advice if anyone has dealt with this sort of repair before.
    • Hi some pictures o& the movement and case would be appreciated so we can ascertain what the problem is you are having in fitting the movement.   Thank you.
