Is the balance staff broken?
Hey guys
Im wondering why the balance gums up after running few seconds by rotating the watch. The balance staff on each side are triangular from a side view - do they look broken? When the watch is fully assembled, there is almost no shake in the balance. In image 2, it looks like a broken staff end in the centre top of the balance, but nothing pops out when pushing with something sharp there.
And the train wheels runs freely without the pallet work and balance.
The watch is from 20s/30s.
Hi there,
No, this is not the kind of balance staff that can break. They are shock resist and almost impossible to break. But they do wear, for 2-3 years of work, and need to be resharpened.
Edited by nevenbekriev
The cup on mainplate might need a polish too.
Pin pallet often refuse to run without oil.
How does the balance run without the fork?   bent pins pallets can also stop the oscilator.
Usually 404 ben club gets folks into this mess.😩
The staff is worn it is blunt. Both ends should have a sharp point just as if you have sharpened a  pencil. The other problem you might have is after sharpening the staff you could end up with it being too short in which case you would need a replacement and that will be hard to find. If you have a watchmakers lathe and you feel you could undertake the task you could make one.
I can't align the balance without the fork, so this might cause the worn staff. The pallet pins looks very straight though.
I dont have a lathe tool, can things be sharpened other way?
I don't get the picture.
 You might end up with a shorter pivot/staff after sharpening the pivot, so the cup on mainplate would need to be moved for re-asjustment.
Never heard of sharpening these without a lathe.
The balance doesnt get in place when I install without the pallet fork. Its like that the fork holds the balance straight. But I wonder even how to get the balance wheel out from the balance bridge, since the spring looks to be fixed to the bridge.
Edited by Khan
The things You write here just show You have no experience at all. Of course, the balance will get in place without the pallet fork. Just some patience and stubbornness needed. You first need to do the free oscillations test, for which exactly this is needed - to put the balance without the lever. Yes, sharpening is possible without lathe. But it is easier to do with one. Actually, almost everything is possible to be done without the specialized tools which are made for the purpose. Just imagination and creativity needed. But, is this important for You? I mean, this is cheap watch with no jewels movement, which will never be more than that.
 Fork only engages with impulse pin ( not the balance staff ) during each swing of balance, any other contact between fork and roller table or balance or balance staff deters or stops oscialtion.
Pivot cone might rob on the cup, in case of too much pivot side shake.
Your image No 1 .
Unpin the hairspring from the stud.
Good luck
    • Hello everyone, My name is Matt and I like vintage watches along with pocket watches. I'm very new to the hobby of watchmaking, I've only been tinkering for about 2 months and I'm happy with some of the projects I've salvaged.  First I repaired This Waltham 17 jewel 18s and that was fun.  Then I repaired this old Zenith movement with 19 jewels. I couldn't find it on the pocket watch database though.  Then I repaired this one Lucerne 1 JEWEL movement. It was actually the first watch I got but it was so difficult to put back together with the fiscal amount of tools I had at the time so I just left it strewn in a Ziplock bag. Then My most recent project that came up a total win was this Longines Caliber 19AS, 17 jewels unadjusted. It turned out beautifully in my opinion and was by far the most difficult to reassemble.  I am in love with this hobby and its kind of engulfed my personality as of right now.  I plan on giving the Longines watch to my uncle, and so right now I'm trying to enjoy that watch the most I possibly can.    What I'm currently working on: A Seiko Automatic with a little date window and a weekday function too. I think its the 6309A.  Then there is this Omega pocket watch. Unfortunately I lost a little screw that held in the click spring. I'll have to source another one because its tiny and my room is filled with carpet, that thing is gone. Then theres this little tiny Elgin pocket watch. It's fully assembled but the amplitude is low and so I think it needs a new mainspring.  Then theres this Waltham 7 jewel movement that I also cleaned and reassembled, but it'll only run facing one way and again with the amplitude being low, I think it needs a new mainspring as well.  And finally, I'm working on this gorgeous Grade no.3 1883 Waltham Pocket Watch. It came with a broken balance staff on both sides and would only run when the watch was like sideways, crown to the sky. I'm really excited about that one though, might be worth something.      I've chosen to not show the other ones because they're not in movement holders right now, and the Omega is not put together.  As you can see, I take these pictures using the flash. Idk why but I like the way the flash makes the metal shine more than just my little lamp.  I'm also very eager to find a replacement for that balance wheel; any links would be appreciated.  From what I could tell on the Seiko, it's just dirty and It should run if I put it together carefully after cleaning.  Also, I fear that that 1883 Waltham may not run too good because of the mainspring, it's probably set because it's so old. I may seek a replacement for that too. I also need to find a crystal for that 18s gold filled Waltham that I've put together. It's just scary having it exposed.      I ALMOST FORGOT to mention. Is this Omega real?      You gotta turn your head a bit but it does indeed say "OMEGA", so I'm confused. I never knew they made pocket watches. And thats why I'm skeptical. Please let me know.    But thats pretty much it. I just wanted to put this out there so that I could begin using the website properly and also to let some people know I exist I guess.  Also this is my second account. I know that may violate some rules but I did the introduction wrong the first time and I wanted to fix it by making a new account. Please don't ban this one.    Thank you all, -Matt
    • Sounds like you and @VWatchie were unlucky. Mine has been running on 230V UK for years  ( it's been 230V for many years @Neverenoughwatches, not 240V).  Though I have had to re-solder some wires. When I buy cheap Chinese electrical components I often take them apart to check they're not going to kill me. Since the demagnetiser, I bought a cheap fish tank heater for my plating set up. Plugged in, big flash and smell of burning. Deader. So I bought a cheap cup heater plate. Exactly the same - flash, bang, wallop.
    • The old crystal is cracked on the edge, and I am looking for something like for like.
