Are these hands salvageable?
What's the purpose of the slot in the bought one? -
By rossjackson01 · Posted
That all? Plastic pill top, small screw through centre. Made. -
Ok, with the parts You have, the easiest thing to do is vibrate a new hairspring, of cousre for 16800 BPH. A couple of balance screws will be not enough, at least 3-4 aditional couples will be needed. And this if You have that many free holes. And cutting 75 teeth table for the contrate wheel is the other reasonable option Different things may have happened to the clock - the contrate wheel may have be replaced from another modification, the platform may not be original, the hairspring may have been replaced and vibrated for 18000 or the entire balance may have been replaced wit the wrong one... -
I also agree with @mikepilk and @Waggy. Your readings look good. The amplitude drop between the horizontal postion and the vertical position is nice and low (only 18° difference). The delta of 17 sec (-3 to +14) between those positions is absolutely ok. If you really wanted to improve on this, I think you'd have to look into the poising of the balance wheel (not the spring, which looks perfect). But that's a total overkill for this kind of movement. Leave it be.
I've just finished refurbishing a Memostar Alarm with AS 1931 movement (same as 1945 but with date and running at 21600). I was also surprised how many parts are available at Cousins. Like you, I was missing the alarm stem (Cousins stock them) and I needed new crowns. It's a nice simple movement for an alarm, easier to service than a Seiko Bell-Matic. BTW I made a note in my Servicing spreadsheet: "Pull out winding stem before removal". It may have just been wear on my movement, but I found that the yoke could move out of the clutch if the stem was removed in the normal position (like some ETAs). You might find this interesting
