Some of you may remember that, some weeks ago, I picked up a cheap Seiko 5 automatic for a tenner - not the nice one with the blue face that I posted about recently, a different one - and discovered that it wasn't holding a wind.
I took the case back off and then the rotor arm to discover that a forked spring or lever activated by the back and forward movement of the rotor isn't connecting properly with a gear wheel - and this is the gear wheel which helps to turn the ratchet wheel, etc... The gear wheel is incredibly worn and not responding to the action of the lever. You can see the offending spring on either side of the worn gear in the close-up below.
To replace or not to replace? The answer, for me, is no. I'll keep the movement for spares as the balance is in good order.
Edited by WillFly
Will, in order to replace the broken part the whole train wheel bridge needs to be removed I regret.
It is secured to the driving wheel with a little circlip which is under the train wheel bridge.
Sorry to be the bearer of bad news my friend.
No worries - I've just sniped a nice Seiko 5 on eBay for a tenner! It's in GWO except for a broken crystal and missing hands. All this happened 25 years ago and it's been lying in a drawer wrapped in a cloth since then.
So. I can decide how I want to play this. My guess is I'll take the hands (they match) from the first one and refurbish the one I've just sniped - and I have another one in the offing on eBay...
It'll end up being a Seiko FrankenFive!
Edited by WillFly
No worries Will...Just find a good Wheel on eBay ( the rotor and his train Wheel ) and you will restart your Seiko 5... a good friend here had a movement for mine ( 6119C ) My movement was missing all the automatic train Wheel and the smal spring that retain the ratchet Wheel, now my Watch works very well.
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
