Back the day, I generally kept several Timex watches that I wore at work, or wore while outdoors.
Two are Indigo models, one a titanium model, and one multi dial World Watch.
Back when cell phones became the norm, I stopped wearing a watch, so I pulled the batteries out of them all and put them back in their original box and put them away in a dresser drawer.
I dug them out the other day and put fresh batteries on them all. Only one would run, the largest Indigo model with a massive face.
I put each one under a magnification lense, and I see no corrosion, and the batteries weren't left in to leak, but only one of them will run, and that one has now killed its new battery in about 6 hours.
What goes wrong with this kind of watch when it sits? They were in cases, and clean. Most look brand new as no one got worn for very long.
Any ideas?
3 hours ago, barnfind said:
Any ideas?
Dry lubricant.
20 or 30 years sitting in a drawer without anything moving and the lubrication is likely to have gone a bit gummy, which is why the one that does run is draining the battery so quickly, and the others won't run at all.
One little trick that you could try is to allow the watches to warm up a little on a radiator or perhaps with a hair dryer. Don't cook them, just get them warm to the touch. With any luck the warmth may loosen up the gummy oils a little and allow things to start to move. You could also try a line release tool to spin the movement up which may get things going again.
Hi another trick to loosen the gunge is put a little drop of benzine or white spirit on the pivots and spin up on a line release.  The movement will only be temporarily work an will need a clean at some point.
Hi a line release is basically a demagnetiser that creates a magnetic field and once you introduce the watch to the field the rotor spins turning the hands. Purpose built  “ quartz watch “ testers have the facility. EBay around £30 .
As marc and ww have stated, just like mechanical watches quartz analog battery watches with a dial face and hands also have a mechanical side that needs periodic maintenance that includes servicing, repair and replacement.  Wise of you to remove the batteries which has saved you some extra misery.  So the line release is a little gadget that operates a small magnet from inside of it. The watch is placed on the device's surface and after a button activation a motor spins the magnet that acts upon the magnetic rotor inside the watch. The rotor is meshed to the mechanical side of the watch hence the gearing up to and including the hands spin to free things up. The old lubrication is still old lubrication and will almost certainly solidify again at some point. Warming up the movement is a good idea and will help the line release to do its job.
I tried the heat trick, it got all but the two newest watches working, and each has been working fine since. The one that kills batteries takes out the 1025/3v battery in about 6 hrs, but I seem to recall it always was a bit hard on batteries, maybe lasting only a month or so when new.
Both of the watches left are Indiglo models. The one that won't run at all is the newest of them, the original receipt is dated 1/3/2000 from Sears. I probably wore that watch for three or four months tops, then it got put away when I started to carry a cell phone full time.
I probably hadn't planned for them to sit forever and simply removed the batteries to cut wear and tear on them just sitting figuring that they'd likely run a few years before the batteries gave out. (A few of the batteries were still holding voltage, and were put away with them in small plastic bags. A few were put away with new batteries in packages I kept around for spares, mostly from Radio Shack at the time. None of those still show any sign of power).
The one that's not running is the one that sat the least amount of time, and the one I most expected to still work.
None are worth much but they were at one time at least reliable.
I wanted to start wearing one again as I tend not to carry my new cell phone on me all the time these days, its just too bulky to carry, so I was sort of looking to go back to wearing a watch.
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
