Hi guys, I have a nice little carriage clock that looks like some of the plating has been polished away.  Is this brass plating?  Is there a way to restore it?
Edited by MikeEll
  • 4 weeks later...
If its solid brass then it will polish, what that looks like is the lacquer that has worn away, So you need to strip the case drop in the tank with an ammonia based cleaner to strip the rest of the lacquer away then polish with brasso and clean again then spray lacquer the case again to keep the shine.
On closer inspection it was solid brass.  I polished an area from the base that wasn't visible just to check.  The finished clock turned out really nice.
4 hours ago, RichardHarris123 said:
Photos please.
I actually posted this under a separate thread.  See here -
3 hours ago, oldhippy said:
Did you lacquer the whole case? If not it will tarnish quite quick.
I haven't done that yet, but good point.
I'm really pleased with the accuracy.  It arrived to me broken and it now keeps perfect time over the course of a week or so.
Edited by MikeEll
I use Mohawk lacquer for brass for all the brass on the torsion clocks I restore
Dell
Edited by Dell
40 minutes ago, MikeEll said:
thanks Dell, I'll add some to my next order.  Where do you buy yours from?
Master finishes.
I forgot to say don’t put it on like normal lacquer, just a dust coat then straight over again with a slightly wetter one but not wet , it looks horrible when first applied but it flows out lovely, try on a bit of polished scrap brass first.
I always preferred to paint the lacquer on, spraying can leave minute bubbles I admit you can hardly see them but you know they are there. Horolacq clear is the one I had and painted on with a paint artist flat brush. I drys very quick.
I found that with most lacquers but not the one I use now, I know some people dip them but I never found that very successful, always ended up with a hard blob .
Dell
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
