I'm trying to fix a 1970's Bulova bracelet that has very loose links. It's not just the links that are loose, the pins at the lugs as well as on the clasp do not look to be correct. Sorry for the wrist cheese in these photos.
1. First, what would be the name of this type of pin that is found on the links? I'm used to seeing cotter pins that have a split just at the tip, not ones that are split the entire length, so I'm not sure what kind of pins I need to order. Are there kits with assorted sizes available?
2. The pins at the lugs just fall right out and they look to be of different types so I don't think these are correct. I think these may just take normal cotter pins but I haven't done a lot of this type of central lug style of bracelets. Are there kits with assorted sizes available?
3. The spring type found in the clasp doesn't look correct either as the pins extend out on both sides way too much. Is there a kit with an assortment for the type needed here?
20 minutes ago, HectorLooi said:
If you do a search for "bracelet pin" in Cousins website, you'll find all the various designs available.
I actually came from there before posting here. I'm not clear on what type of pins are needed to replace the ones shown as I think the ones on both the bracelet clasp and lugs are not correct, so was wondering if anyone had suggestions on the correct ones.
For the link pins, I looked on both Cousin's and Esslinger and can't find a split pin that runs the entire length of the pin, they all are the typical cotter pins. Is there a name for those types of pins? Or maybe the ones that I show are the typical cotter pins that have just been stretched/expanded along the entire length?
Edited by GuyMontag
The split does run the entire length of the pins. They are different from cotter pins in that the ends are the ones with the "bulge", and not a loop folded over.
I use split pins most of the time. Sometimes I just use ortho wire, 1.2mm or 1.5mm and hammer a flat portion and cut it to length. A drop of Loctite for added security.
there are so many stiles of pins, screws, rivet, pressure and spring bars for watches, the one in the buckle is a springbar for sure, buckle springbars have a shorter end so as not to protrude out from the buckle itself and fit flush, but the the fold over part of yours looks to have been cut with only a smaller center piece holding the springbar or it has been flipped around and goes between the other part of the fold-over, if Cousins does not show assortments of the parts mentioned then look on eBay or other material houses, like Jules Borel, Cas-Ker, Esslinger etc. for ideas, the fold over pins are probably correct for the band links, the band to case could be different like the center tube notch and pin type...
3. The spring type found in the clasp doesn't look correct either as the pins extend out on both sides way too much. Is there a kit with an assortment for the type needed here Visit https://braceletwithpictureinside.store?
Hi. I have seen 16618 (both black and blue dial ones) with bezels that have yellow, gold and white fonts. My question is which type of bezel is the more correct one? Or were they just mounted on 16618 randomly through different periods? My second question is about the bracelet. When did Rolex stop using pin bracelet and switched to screws? (pin on removable links vs screws) Thanks!
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
