6 minutes ago, RichardHarris123 said:
trying to pry it will damage the threads or lock it tighter
Of course, I didn't think of that. Thanks for the heads up!
2 minutes ago, RichardHarris123 said:
Can you print a die for it?
I'm afraid not.
If not and this is just a  thought, select a  socket just wider than the bezel and fill with hot glue from a glue gun, try and rotate. Might be a terrible idea.
Hmm... Anyway, all ideas are more than welcome. Who knows, perhaps you're on to something.
52 minutes ago, VWatchie said:
On 2/2/2024 at 9:34 AM, Malocchio said:
have this. Great if the bezel is so stuck that a knife is no good. Kind of a spring loaded hammer.
That's an interesting idea. I'll give it a try and see if something happens. If the bezel is screwed on I guess that the worst that can happen is... nothing
Kalle Slapp used this auto punch style back remover in one of his vids. It could damage the bezel edge or the threads if the bezel is screwed on. Thing is any damage is more evident to the bezel than the back.
A very similar Sinn with Unitas 6425. I bet the bezel is screwed on.
But for a cheaper watch like yours the screwed bezel might be to expensive to fabricate.
Edited by Kalanag
5 hours ago, RichardHarris123 said:
Have you managed to remove the bezel?
Nope. I tried to screw it off and to pray it off using a Micro-Shock Case Opener but to no avail. I'm beginning to suspect it isn't removable as there is no real need to remove it. The only reason for me to remove it would be to make it easier to polish the case, but I'm thinking perhaps it can be protected with a couple of layers of Kapton tape!? 🤔
I've been contemplating getting a  Stanley knife as demonstrated by @Jon but not sure it is worth the risk not knowing if it indeed is removable.
  • Sad 1
Just a quick update to let you know I was able to satin polish the case without removing the bezel which I protected using double layers of Kapton tape. Even so, the diameter of the bezel was considerably smaller than the case so the tape was just a precaution. So, the case is looking like new again! 🙂
Now just waiting for new mineral crystals for the case and case back which seems to take forever. I think I'm done with Postnord 😠
Edited by VWatchie
14 hours ago, RichardHarris123 said:
Post photos , once finished.
Will do! And I hope it happens during this lifetime considering the insane long delivery times from Postnord, who have charged me double VAT despite being an IOSS order from CousinsUK. Since BREXIT the EU has been punishing Swedes doing business with Britain.
Rightly or wrongly the British public voted for Brexit. I found the EU response astonishing, rather than "sorry to see you go, let's sit down like adults and work out how to proceed ", they spat the dummy like a  petulant toddler.
On 2/20/2024 at 11:06 PM, RichardHarris123 said:
I would of liked to know the answer but glad it worked out.  Post photos , once finished.
The polishing worked out well. It only needed a bit of satin brushing on the sides and mirror polishing of the case back. The reason I got this watch (in dire need of a service) was because @nickelsilver spoke well of Peseux. Now this movement (Peseux 7040) probably wasn't their top-of-the-line but still performs very well after a service. No repairs (except replacing the scratched-up case and case back crystals) or adjustments were required so easy to work on. Here are the numbers.
Fully wound minus 1 hour:
Dial up:
Rate: +5 s/d, Amp.: 310°, B.E.: 0.1ms
Dial down:
Rate: +3 s/d, Amp.: 305°, B.E.: 0.1ms
Crown left:
Rate: -1 s/d, Amp.: 260°, B.E.: 0.1ms
Crown down:
Rate: +8 s/d, Amp.: 265°, B.E.: 0.1ms
Crown right:
Rate: -5 s/d, Amp.: 275°, B.E.: 0.0ms
Crown up:
Rate: -12 s/d, Amp.: 265°, B.E.: 0.1ms
Fully wound minus 26 hours:
Dial up:
Rate: +4 s/d, Amp.: 265°, B.E.: 0.0ms
Dial down:
Rate: 0 s/d, Amp.: 270°, B.E.: 0.0ms
Crown left:
Rate: -6 s/d, Amp.: 240°, B.E.: 0.1ms
Crown down:
Rate: +2 s/d, Amp.: 225°, B.E.: 0.2ms
Crown right:
Rate: -3 s/d, Amp.: 223°, B.E.: 0.0ms
Crown up:
Rate: -12 s/d, Amp.: 223°, B.E.: 0.1ms
Edited by VWatchie
  • Like 5
  • 2 months later...
On 2/1/2024 at 8:36 PM, Jon said:
Here's a link to my cloud storage where a video of removing a Rolex bezel.
@Jon The link is no longer working and I wanted to see that demonstration again. Is there any chance you can make it available again? I'd appreciate it!
I'll have a look for it, but don't hold your breathe. Failing that I'll make another video when another bezel needs to be removed.
I put this quick vid together today when I was replacing the tropic crystal on this Rolex Oyster Perpetual.
It wasn't the greatest filming, but hey!
  • Thanks 2
Thank you @Jon, much appreciated! 🙂👍
What type of hammer are you using and is the type of hammer important?
EDIT: I reread your previous post about a brass hammer. If we use too much force, the damage will go into the hammer head rather than the watch case, right?
EDIT: I decided to see the video on YouTube and your comments were helpful. My only remaining question is how do you accomplish a "blunted blade"?
EDIT: Thinking about it I'd like to know a little more about the knife too. Had a look at Stanley's website but couldn't find a knife looking like yours. Likely no longer in production. Perhaps any sturdy knife would do?
EDIT: Had a look at brass hammers at Cousins. What weight would you recommend?
Edited by VWatchie
Yes, Mine has a support for the blade that can be safely hit like this one https://www.amazon.co.uk/Rolson-62841-Tradesman-Knife/dp/B0044D9MC6/ref=sr_1_37?crid=3HWJF1HL4J8D7&dib=eyJ2IjoiMSJ9.X58oai8WcFho_-XqfR-lLQbU8lQKhf1vtFKAWbXR4EAhqVWR_eMy5h1DhaCULvkpA6XT0GaNFLHt_kJ0kPrhXFo0nYd8yJ4JgruoXDG9XjViAQOyAiBUkOhC9W9qQfGr0SMKpxIUrGOBkTjtTPTuM9IOTnb-dEAzbcZVvniVcEuMFGK9SITyDO6ryUU8ERkHt8f2Vy9Ks0QFO06KSJz65C2p7S3o2lOaUoO9kw61KyNtaaYYwdZzyuM2uRywODaigUn0u8RHMPR0dOa3WSrq8vE1iV5Et_561SFfvkhSGTQ.9QrdWVoCJpLVkrflNS1sxaY56ys4iiJspEFpUgLIRdg&dib_tag=se&keywords=stanley+knife&qid=1716289527&sprefix=stanley+knife%2Caps%2C77&sr=8-37
I use a brass hammer. You could use a very light pin hammer. A watchmaker's hammer would be a bit too light to use. I'm not sure of the weight, but looking at Cousins, it looks like a 60 or 84g brass hammer. I would go with the 84g one. A lot of the process is about feel, so you don't damage the case or bezel. Don't twist the tool! You may think it would make it easier and quicker, but that's when the damage starts to happen and be especially careful around the lugs.
Once you have done a couple, you'll get a feel of it. Some bezels feel like they're not coming off and you start to doubt what you are doing. The trick is to be deliberate in your actions, rather than tentative. If you perform this task with the total belief that the bezel is coming off, that is exactly what will happen. First, be totally sure that the bezel comes off in the way you expect.
Rub the blade against a piece of 400 grit wet and dry until blunt
Edited by Jon
Thank you for this very practical advice @Jon on what to do and what not to be tempted to do. When you learn something you always make mistakes but with solid advice from someone with experience, mistakes can often be minimised. Very valuable and appreciated!
Thanks for the tips, @Jon and especially for the video demo. I’ve struggled with this and knew there must be a better way.  I’m always fearful of the potential for inflicting damage, but the method you show allows for better control in the process.  Great tip too about dulling the blade with 400 grit paper.   Big thanks.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
