7S26 balance spring, what's up with it
Working on a 7S26 for a mate, I've got a new balance in the mail because I'm not super confident I can fix this, but I'd still like to try.
It looks like the spring is pretty mangled to the right of the regulator pin, so I'm wondering if it might have been originally clamped in the pin there, and it's just slipped back a bit? Should I attempt to insert it more into the regulator, or should I leave it where it is and try and reshape it?
You definitely need to reshape the endcurve and put the hairspring in the slot of the regulator. The regulator stud can be rotated to align the slot with the hairspring.
Seiko uses a system similar to Etachron. To remove the hairspring stud, you can use a fine tip tweezer to carefully wedge the stud out of the clip.
Hi lex, some centering of those coils needs to take place. First make sure that the hairspring is thoughly clean and nothing sticky remains, magnetism shouldn't be an issue as modern ( last 70 years bright nickle alloys ) hairsprings are non magnetic. Next check its freedom between the regulator pins, which at the moment doesn't look like it is, seems to be nipped, notice the gap between the end curve and the.1st coil is wider on both sides of the regulator. Once free turn the stud for some concentric adjument of the coils, if that looks ok then the regulator pins can be closed up and checked for hairspring freedom all along the terminal curve. Maybe some reshaping of it like Hector suggests as the curve looks a bit raggy.
Yes, reshaping of the end curve is definitelly needed. This can be done without taking out hte stud from the holder at all.
The spring is not clamped in the stud, it is glued with heat melting glue and it is not protrding from the other side like in old watches that have 'reserve'. So it is as it should be there.
Edited by nevenbekriev
@lexacat reshaping hairsprings is more of an art than a science, sometimes you take a spring and make a minor tweak and everything miraculously falls into place (those are the good days), other times you can be 99% done and make a final micro adjustment and it ends up worse than you started. But practice and experience will get you there in the end, you can go from this:
0121.thumb.JPG.7ed6461bf5a1eaf883a016603438a0e0.JPG0122.thumb.JPG.728184d5b3b2422a7049d441ecb9e9b5.JPG
To this:
Only general advice I can give is to look for the problem area (eg where the coils are touching) and then look 90 degrees away for the cause and make your adjustment, when making an adjustment hold the coil with a fine set of tweezers (No 5) and then stroke the spring on whichever side of the held section works with another set of closed No 5's or thin tool (eg oiler) to make the adjustment - repeat as necessary, if you try make an actual bend you will inevitably overdo it and start the downward spiral of fixing the fix, then having to fix that fix......take regular breaks to avoid frustration and re-fucus your concentration.
On 1/29/2024 at 7:27 PM, lexacat said:
mangled
I think mangled is a bit of a harsh word here. let's interesting in the world of horology the battle of Japanese watch manufacturing with the Swiss is that sometimes they share things like the system here of the regulation on the stud commonly called a Etachron system the Swiss hold the patent for one part and the Japanese hold the patents for the other part.
I'm attaching an image so you have a better idea of how things look. For now what I would do is just open the regulator up to its maximum and just move it out of the way see you can see if they hairspring got bent there. you and up with way more adjustments which of course will cause way more confusion when you're trying to figure out what you're trying to do here.
  • 4 weeks later...
Hey guys, thanks for all the great info! I've been snowed under with work but hoping to have a crack at this when I get a spare second. I've got a new balance to pop on this if I screw things up, but hopefully I can get it looking good again 😃
    • A couple of pictures of the front… Sorry, I’m months away from this one, but…there is an edge to the bezel but I see no obvious signs of previous bezel removal and it is quite thick so it would be difficult to grab an edge on the crystal with a crystal lift. It does look like in/out thru the back…good luck…
    • Personally I would salvage the missing screws from some donor movement.  I also bought a random selection of screws "Assortment of Stainless Steel Watch Screws" for next to nothing.  As for using an Alum solution - I had great success with that removing a rusted stem from a stainless steel crown.  The best piece of advice I read on doing that was to keep the solution warm so that the reaction didn't take weeks!  I did it in a couple of hours with the solution in jam jar and the jam jar in a saucepan full of water which I left on an induction hob maintaining about 60C in the Alum solution.
    • I decided that it was time to tackle the piece that I'd set aside as my first project. The subject in question is a Gruen Veri-Thin pocket watch.  It winds and "runs".  On the time grapher, it has reasonable amplitude (240 or so depending on the position), but was loosing close to a minute a day.  The stem also has the annoying tendency to just come out when pulled, which makes it super hard to set the thing.  As with many things this one started sideways and just got more so.  I was able to overcome the mangled "tab" on the back case cover (a well placed, very sharp knife enabled me to get in when I couldn't get a purchase on the mangled tab with a case knife.)   I was then sort of shocked to find that one side of the dial was held down with some sort off tape or adhesive material as someone had broken the dial foot screw on that side and left the broken screw in the mail plate. The loose stem does in fact seem to have been a poorly tightened setting lever screw, but I'm afraid there may still be gremlins in the keyless works.  While I was able to get the stem to stay in by putting everything in the right place and tightening the setting lever screw (before I took it all apart for cleaning and inspection), it just didn't seem to all sit right. The final gremlin showed up when I was taking off the lower cap stones for the balance and escape wheel (yes the Gruen 380 seems to have a cape jewel on the escape wheel).  The balance stone came off fine (but that in fact is the smallest screw I've ever seen.  When I turned the movement around to get the one off the escape wheel setting, I found that the screw head had been mostly sheared off.  After some reading and looking at what I had, I decided to try and tease what was left of the screw out of the hole by nudging what was left with the corner of my smallest screwdriver.  After 20 minutes or so, I was able to get the remains of that screw out. The picture I'm including of the disassembled movement was taken before I got the second cap stone off, so in the picture, it's still attached to the main plate (for those looking carefully, you'll only see the one cap setting in the pic.) Now I'm left with: A broken dial screw inside the main plate that needs to come out A broken cap stone retention screw that I have in my parts tray, but that is strictly useless and needs to be replaced. The need to get another dial foot screw I'm contemplating solving the first problem by soaking the main plate in an alum solution.  I think the main plate is brass and shouldn't be affected, but I have not been able to confirm.  This seems like the easiest option as I can't really access both sides of the screw to use the pricey Bergeon tool (which I don't fancy buying unless I have to.) I have located a couple of donor movements and have questions out about whether or not the include the dial foot screw and prompting for pictures of the dial side so  evaluate the cap stone settings.  I've also found that a supplier in this country does have the cap stone settings, but isn't overly clear about whether the screws are included. Are these the types of things that one can scavenge out of assortments or is it best to just grab one of the donors assuming that they look like they have what I need?
