Submariner Crown and Stem Problem
By watchweasol · Posted
Hi. Bit of a difference now, as OldHippy said as long as the belt is in line with the pulley it’s ok. With the reversing lever on the right end it keeps your fingers away from the pulley / belt area. -
Hi Gary welcome to the forum. Attached some reading , might be useful TZIllustratedGlossary.pdf -
Its this number in brackets Michael, it is the total number of transactions of both sales and purchases. The higher the number the more reliable the 100% feedback. -
the lugs/bezel insert look like Omega Speedmaster, Omega does use screw-down crowns on some models but not sure what you have......I wish you had the back
