Hey again watch peeps. Finding a really good repair book can be a bit hit and miss, and when a recommendation comes along it can get quite expensive. So here a little discovery i made yesterday that should only cost you a few quid. I've had this book on my shelf for about 18 months, its not a big book around A4ish size with 200 pages and old, almost a 100yrs for the 1st edition. Now most of us have heard of Aegler, basically the manufacturer that put Rolex on the map, without Aegler they might not be what they are today. They had a very long partnership starting about 120 yrs ago, from what I've read more or less in each other's pockets since the 1920's, slowing blending together to finish as one company in 2004. The Aegler family also included the Borer family, through marriage ? The Borer family did buy out Aegler in the late 60's who eventually sold it to Rolex. One member of the Borer family was heavily involved with Rolex's design and technical department creating the Rolex Perpetual among others during his time, he was also on Rolex's board of directors this would be Emile Borer. I only realised yesterday after some reading that the writer of my book E.Borer being the same guy. For a few quid must be worth a read is it not ?
31 minutes ago, tomh207 said:
@Neverenoughwatches
i just ordered a copy Rich, got to be worth a punt for a fiver
Tom
The price can vary, i have seen it anywhere from £3 -£30. I guess its knowing what you are selling. I've only just started to read it. The section on escapement is really good even the  guy apparently had a brilliant mind its not super technical, inside is a pull out illustration showing 30 points to watch and why things happen if they are not set up correctly. The book was wrote shortly after he designed the Oyster Perpetual the worlds first fully reliable automatic watch.
I have the same book and it does indeed have a lot of useful stuff in it.
You had me a little confused when you described it as...
A4ish size
as my copy is almost exactly A5, but it is the same edition as yours, just love the adverts in the front..
If I remember rightly mine was just a couple of quid in and antiquarian book shop.
Haha yeah its sort of inbetween 4 and 5 ish. maybe more 5ish 😅. Mr. Borer keeps it mostly simple, the articles are 100 yrs old ish thats just how folk were then, some of it feels like he's educating a nine year old which suits me just fine 😄. Its interesting reading his views and theories on cleaning and lubrication, oil movement within components like the escapement and the very start of using chemicals for oil adherence and retention, its very clear that he loved an experiment or two since he was head of technical department of the most famous watch brand in the world. Even at almost 100 yrs old its made me look more closely at what i do, definitely should have read it a lot sooner.
    • Why do you think this is Fontainemelon ?
    • Hi Watchrepairtalk, I have some questions about part sourcing I was hoping someone here might be able to help with. I'm working on an FHF 180 movement with a broken balance staff, broken regulator pins, and damaged cap jewels (both top and bottom). Some Googling says that this is similar to other FHF calibers like 150s, 160s, 180s and so on but I can't figure out what the functional difference is between these movements.  Is there any reason I wouldn't be able to acquire a donor FHF 150 or similar (with no shock protection) and use parts from that or would it be smarter to source replacements individually? Also are there any sources someone could recommend to get bulk cap jewels like this? Thank you for the help!
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
