Question About Priory Polish Cleaner
I have just bought 250ml of Priory Polish Watch and clock cleaning fluid after reading good things on here about it. I have just been doing a Seiko 6119 and found it really difficult to shift the old oils etc. There was a greenish crud that was everywhere and it did not want to budge, it took me several goes with my usual degreaser and then lighter fluid to get it off. So I thought I would give some Priory a go on my next victim. I am using a small ultrasonic cleaner at the moment with various baskets and cages for the parts. I was wondering whether it would be ok to dilute the PP cleaner with hottish water, and if there would be any advantage in doing so.  It also says that the fluid can be reused, what are your thoughts on this? I can see how I might use some again to clean the dirtier parts such as the barrel and spring etc but I would be reluctant to put other smaller part into old fluid.
Hi Davey, I dilute the cleaner one part cleaner to seven parts water and put it in a jam jars with a screw top.
First give the parts a rinse in lighter fluid to take off the worst of the grease and oil.
Now place the parts to be cleaned in the jar with the diluted cleaner, and place the jar in the ultrasonic cleaner which has been filled with water at 50C. The parts are then blasted for around five minutes, or as long as it takes to clean them.
I tried out the cleaner a couple of days ago on some parts that I thought were "clean". There was some green debris left in the gear wheels that were stopping the watch from running so I stripped them out again and gave them the Priory treatment. Fantastic results!   I feel as though I have been wasting my time with the other stuff.
Converted now.
By the way, I used it as advised here and put some into a small jar containing the parts and plopped it into my small ultrasonic and it is a great method and economical with the cleaner too. Would it be less effective if used in a slightly heavier walled jar or container, would the ultrasonic effect be diminished a bit?
From what I understand glass doesn't interfere with the cavitation process in an ultrasound so thickness shouldn't make a difference. The less solid the container (for example I have heard of people using solutions in plastic bags) the more the interference. It will still work, but not as well as in a glass jar or just straight in the tank. I just use different size glass jars.
Stephen
    • Forgot to mention that only demagnetize a balance when its in the movement, otherwise the magnetic field will snatch the coils and damage them
    • Sometimes a sticky hairspring might unravel after using a demagnetizer. But if you push the coils until they touch, they will stick together again. I find that brushing the coils gently while submerged in naptha the most effective way to cure a sticky hairspring. Sometimes it requires 2 or 3 washes to cure it. I often wondered what causes a hairspring to become sticky. The 9010 in the jewels are unlikely to drip onto the hairspring. The other possibility is the 9415 on the pallets. But then that's on the other side, below the balance. Can it "splash" onto the hairspring?  Looking at the stickiness and tenacity, I'm leaning towards 9415.
    • I was about to ask the same question, it sounds a lot like magnetism which is a quick fix (assuming you have access to the correct tool) and ideally something you should do anyway.
    • Nice! I have lately been buying up a handful of Arnex pieces on eBay because it is often obvious even without photos that they house a fine Unitas 6498. And many of the 1970s cases and "old timey themed" dials are irredeemably ugly so they are a cheap way to pickup great movements to power custom wristwatch projects. All of the ones I've bought were in like new condition, barely used assuming they were bought as graduation or retirement gifts in the 70s or 80s.
    • Walked by my local jeweler today and asked if I could dig around in his old watch case, and picked this guy up (along with a cool vintage compass and a Seiko kinetic5M62). My girlfriend's son asked if he could borrow one of my pocket watches for prom, so I thought if I can get this guy running it'd be a nice prom gift. Non-running. Felt like the balance was overbanked, but it turns out the train was jammed solid. Looks like it was just dried lubricant gluing the 3rd wheel in place, because it's clean as a whistle otherwise. Parts are in the ultrasonic right now.
