Hi everyone,
Some time ago you were very helpful in assisting me repair this old Normana, I love this watch as it was the first I managed to successfully repair. However, recently (don't ask me how!!) I managed to snap the stem off the crown. As you can see from the photo, part of the old stem remain inside the crown. So....ordered a new stem, but I cannot find a replacement crown as every time I search for FEF190 Crown I only ever get other parts that are NOT the one I am looking for - I can't see that it's called anything but 'Crown' - any help gratefully received!
Tony
Edited by Watching
Quote
Thanks, but now you're talking the Dark Arts!! How would I establish the appropriate sizes??
Forgive the stupid typo in the subject title too.....serves me right for rushing!
According to windingstems.com the thread is a tap 9. The other dimension that you need is the diameter of the crown which you can just measure your old one.
If you need a new stem as well then try here.
Two ways you can repair this crown,
1- Drop the crown in alum solution, which disolves the stem , might need three to four tries to dislove it all.
2-File off about a mm of the free end  of the tube ( file off the tube leave  the stem intact ) you then have a mm of the stem not surrounded by the tube ( sticking out ) which you can grob in pliers and unscrew the remaining stem out. Dress the remaining section of the tube.
    • Thanks for the info - I'll go big on the gaskets... Wonder if anyone sells hundred packs?!
    • Looked into this some more and I believe that some of the increase in rate is attributable to the drop in amplitude after 12 hours off wrist, from 300 to 275 degrees horizontal and some is due to the lower temperature (38 to 18 degrees). I can see that approx 3 to 4 seconds a day is attributable to each. I can be happy with that.
    • Link below shows the tool used to push the stud out. You can make the tool , just file a screwdriver to this shape.  https://www.esslinger.com/bergeon-16918-etachron-stud-remover-screwdriver/ There are vids on YouTube showing how the stud is to be  push out. Shouldn't get over creative, just go by this approach.  Good luck.
    • Hi all, I'm almost ready to make my first attempt at watch repair. My initial goals are very modest, just to get an inexpensive watch or two to work on, and take it at my own pace. I have what I think are the necessary tools on the way. A couple of things arrived already: a loupe, some tweezers, and a cheap demagnetizer. After looking at the options for oils and grease, I decided to start off with Citizen A-O2 and A-O3 oil, and Seiko S-3 grease. The Moebius was just too pricey to buy this early into the undertaking, when added to the cost of the other tools I've bought. Screwdrivers are Kwong Yuen for now, but I took the frequent advice on tweezers and bought Dumostar 3C and will probably add more DuMont later. I'm looking forward to making a start. I'll need a watch to work on, so I'm trying to line up an auction purchase within the next week. I've been mostly looking at Seiko and Citizen, and will perhaps a Seiko Crown if I can land one at a decent price.
    • I tried pushing to dome the washer in and had no success, but stuffing it full of o-ring gaskets worked much better than I expected. It takes some pressure but not as much as you might imagine, but it does take patience ... and a couple of dozen small gaskets. I used the pendant tube of a watch case to stuff the gaskets in as I didn't have a way to machine a tool to suit.
