Omega X-33 not coming out of "energy saver" mode with new battery
By nickelsilver · Posted
Yes- and even cheaper straight from the maker (and 30% off on top of that right now, 240 Euro) https://www.toolteam.com/de-DE/kaefer-jka-feintaster-40001-t-766312-4031452400014.html -
In the Ebay link above, you get 1ml of 9010 for 16 pounds. 2ml, in factory sealed bottle, from Cousins, is 17 pounds. They do have Kluber P125 in small quantities, which is interesting. But a lot of it really is false economy. I think a lot of people just assume that oil is extraordinarily expensive across the board from every supplier- it's often not just more expensive from these re-packagers, it's literally the same price for half or less quantity. -
By BFernandes · Posted
Thanks! I just need to find a decanter within the EU. -
yes the end stones on the balance are flat on one side curved on the other. So yes curves side out unless you would like to reduce your end shake and have issues like you're having. Oh and minor technical problem the lift angles 50° according to the tech sheet. you dropped off a specification like the watch was fully wound up or its 24 hours later? So dial-up and dial down should be as close to identical as possible you have 221 and 215 maybe it's okay but it seems like they should be a little closer. Then as soon as you go to the crown positions dropping below 200.this is definitely a problem watch companies don't care about the maximum amplitude sort of in not supposed to go above 315° on this watch but at the end of 24 hours in the 6H which is basically the 6 o'clock is up at the end of 24 hours it cannot go below 200° and basically all of your crown positions are unacceptable. Here is what the specifications are you will note that watch companies do not get obsessed with amplitudes like they do in this group. They only get obsessed with amplitudes at 24 hours for which this watch is unacceptable. although I'm assuming and I hate to do that that this watch is probably fully wound up and it 24 hours probably a miracle if the watch runs at all.
