Citizen Promaster 7817 movement battery replace
Hello all I was wondering whether a staking set could be used to replace friction fit crown case tubes?
Could be that very reason that the ruby pin is bent, i did take a few photos but the issue doesn't show as bad as it is in the flesh. As it happens, i swapped out the balance and didn’t reposition the pallet pins because the tg trace and amplitude is amazing for a pin pallet. 2 + 3 pictures are DD at 1 hr and at 12hrs after fullwind, 4+5 pics DU 1 hr and 12hrs and 6+7 pics are CD at 1hr and 12hrs -
When demagnetizing a balance thats not in the movement, I put it in a small jar with some hexane and place that on the demagnetizer. That way the coils won't get damaged.
I get ya 👍, not a poundshop window sign that says " cheap bargains galore " more of a " value for money treasures" moniker -
Try rubbing/rolling a piece of rodico on/over the parts after pegging the jewels and the really dirty bits (like inside the barrel etc). You'll find that the rodico will remove most of the dirt.
