New watch with Miyota 9039 -- A bit concerned with results/want to make sure nothing is wrong
Hiya watch people, any more ideas on what to do here yet ? How about just adding ourselves to waggy's list for now. You dont have to add your full name and an email that can be trashed takes minutes to set up. -
By Michael1962 · Posted
Certainly looks like a ring that needs unscrewing in that photo. It definitely looks like a thread above the castellated ring as well. Separate to the caseback ring thread. It even looks to be a smaller diameter. I would expect that. Once undone out of its thread, it should fall out of the case. Would it be possible to make a tool shaped like a letter H with one side of the H engaging the castellations in the ring and the other side of the H for you to be able to unscrew it using your hand? Making a tool with 6 'legs' to pick up all of the castellations would be a labour of love. -
Can anyone advise how to remove the crystal from a Vertex DD case ? I think I need to unscrew an internal retainer ? It definitely isn't just pushing out.
Alright, the job is done. I first filed down the stubs flat. I then used a Proxxon hand drill first with a 0.5mm bit to score a point to work from, then a 1mm drill bit to properly drill out some lug holes. I just went slowly, checking the depth as I went. I drilled the inside of the lugs, leaving the outsides unblemished. I was worried that drilling at an angle might be a problem, but it turned out fine. Lug holes don't need to be very accurate, so it was actually easy to create holes to easily accommodate a spring bar. The result is a 'good enough' outcome that worked for me. Thanks for your help everyone, loving the hobby so far. I learn so much with each project.
By watchweasol · Posted
Welcome to the forum. Yep not a cheap hobby by any means , Ali Express, the Chinese Amazon has some decent tools but should ask the members their thoughts before purchase. A little reading to help you along. TZIllustratedGlossary.pdf
