Orient 46r40
2 hours ago, vivat said:
orient cal 46R40
good and bad of your question? The reason I'm saying that is I looked at this and I thought what the heck is this no pictures but because you didn't give me a picture I did a search for the exact part I quoted up above and it's always amazing what you can find online by doing a search like for instance this. I assume you'll find what you seek their.
Anoth
Another home remodeling problem nipped in the bud for me, thank you. I was just getting attracted to Orient watches, and without this post would have needed a contractor by next week. My propensity for leaping large before I look would have necessitated the building of the Orient wing at my house by now.
Edited by Galilea
No reason since I was still unable to remove dupe quoted matter
Well, that's the incorrect calibre, I've already searched for 46e40, now I need 46r40. Please be more careful what you say, because these two movement's are totally different. In 46r40 there is a power reserve indication etc. So I asked for an oiling map for this direct movement
Unfortunately, technical documents for the various Orient movements are difficult to find. Likely, your only approach will be to study other technical documents of Orient movements (like when I serviced the 46E40 calibre) and then use your general experience and knowledge of oiling. If unsure of a particular part or section, take some macro pictures and I'm sure some experienced and generous pros like @JohnR725 will be happy to share their expertise.
A certain amount of humility is a good way to get professionals to share their knowledge.
so you suggesting my answer was inappropriate so that I can learn from my mistakes?
For sure, as much as I understood from your answer (English is not my native language) it was rather offensive. Anyways this platform is not for trash talking, so thank you for any answer
unfortunately technical literature is often extremely difficult to find. For this watch I looked in the usual sources and I can find nothing. this is where you make use of other watches that are similar including other brands or anything you can find because that's all you're going to get.
I'm sorry that somehow I've offended you and you feel I talk trash let's solve the problem forever.
If you roll your mouse over somebody's name I suggest you do this for me a image will pop up just like this
you'll notice I circled something if you click that you go to another page it looks like this
the analysis of this discussion is my method of communication conflicts with yours. As I didn't recognize this and I still don't recognize exactly what I've done the easiest solution to this is to avoid these unpleasant situations forever. then yes message boards have these features for these type of situations it solves a problem permanently
    • Thats a good record Michael,  i always do a quick scan through sone of the  feedback comments to make sure there are a good few of them relating to sales and not just purchaese.  Feedback can be faked but you can usually spot the dodgy sellers. I have heard that before about lots of orphan watches in Australia 🤔. How far overseas are you going with buying ? There are lots of good sellers here in the UK, shipping is a bit prohibitive though. Main reason for seeing non cased vintages watches would have been the scrapage of the precious metal cases. I think we decide early on what we want from the hobby, whether that is to repair for the fun, enjoyment and sheer challenge of learning something obscure.  To collect watches and have that ability to maintain them, to gain financially from re-sale or a mixture of those. Its also important to remain aware of how deep the rabbit hole goes and how much money it takes to continue the descent.
    • No, trus me, this is totally wrong. Firs of all, there is theoretical lenght for a fixed other parameters (spring thickness, barrel internal diameter and arbour diameter), which will give maximal power reserve. This is written in all text books, but I have never seen in  the text books mathematical expression (formula) of the relation lenght/power reserve. I am to lazy to generate that expression now, but will draw for You the graphical representation of it. As You can see, there is a maximum in the middle, but the slope near the maximum is really small, so even change of the lenght of let say +/- 30% doesn't lead to significant change of the power reserve. More to that, sometimes movement designers put much longer springs in the barrels than the theoretical lenght for maximm reserve.  This is ecpecially in high grade movements. You will sometimes see that the spring covers not the half, but actually 2/3 of the barrel free space. The designers compensate this loss of power reserve by usage of bigger barrels. This way they achieve much smaller difference in full wind / end of power reserve torque. In such case, reducing the spring lenght leads to increasing of power reserve...
    • Hi you can get parts/ tech sheets from cousins uk on therir down lost page, also print rest has some scattered about, cas ker, Esslingers, my retro watches, watch guy there is a few to trawl
    • I only buy mechanical personally, as it's all that interests me. There are a few electronic movements I find interesting, but they're not the sort I tend to see very often at all, and wouldn't come up in any of my searches. I have been given a few quartz watches over the years, but they all just sit in a bag in a drawer. Once I hit some critical mass, I'll hopefully get enough motivation to either sell or donate them.
