Good Day Everyone,
I am a new member to Watch Repair Talk and a new horological hobbyist tackling my own personal repairs as needed.  I have been tinkering with watches for a few years on my free time starting with non-function pieces I picked up from swap meets, garage sales, estate sales, etc. with successes or understanding of complications and how they work together.  Recently one of my personal time pieces (a prized possession of mine) was due for service, an Omega 1164 (ETA7750i) Calibre Seamaster Professional.  After seeing the costs for servicing from various places, I subscribed to Mark's YouTube Channel and decided to tackle the task myself spending the equal money for a repair on "proper" tools and lubricants to complete the task and I DID IT (Thank you Mark for your amazing videos, I couldn't do it with you!)!  After much pride and bragging among family and friends that cared to listen I kind of became the go to for battery replacements on quartz movements and band replacements.  Recently a very good friend of mine came to me with a damaged timepiece that was more a user error issue and asked me if I would be willing to take on the task, and like a junkie or addict I jumped to the opportunity.
The piece in question is a Bell & Ross Military Type 123 (ETA 2895-2). The time piece had a run in with a door jam and had the crown and stem pulled from the timepiece with such force that it firmly pulled the screw down attachment for the crown from the case (please forgive me if I am not using the appropriate terminology).  My first thought was with that much force there must be damage within the movement, so I began the disassembly.  I manged to get it apart and cleaned and started the assembly but immediately ran in to a problem.  The gear train assembly is jamming when I put the movement together.  I worked to gently tease the pinions in place and have had them seated in their bridge but they bind up?  I have seen the videos for ETA 2892 that Mark has posted and understand the care of working with the second wheel, third wheel, and escapement. the trouble I am having is the moment I place the escapement pinion in place under the bridge the second and third wheel seize up.  The second and third wheel will rotate freely but then they both stop when the escapement is in position.  The movement itself is strange to me with the elongated pinion on the escapement that passes through the main plate to a jewel on the underside floating above the plate?
I hope that this question makes sense to the more experienced and that they may be able to shine some light on my problem, I have checked the wheels and all of the pinions appear to be in tact. Thank you everyone for your feedback and support.  I worked 2 days after work on it for a total of about 4 hours which is crazy for 3 gears and a small bridge...I am at a loss.
Hi Scott, Are you working with a bare main-plate, train wheels and bridge? This is the best way to ensure the train is in order as you can view it from all sides to ensure that the pivots are not bent (which may be the case if the watch has had a hard knock).
Everything else should be off the watch, calendar stuff, keyless works etc... just the main bridge, escapement and the bridges to hold them in place.
Anil
Hi Anil,
I do have everything removed from the main plate. The only thing assembled was the barrel and the barrel bridge. I didn't think to remove the 2 and see if there is bind there. Strange thing was the timepiece was running when brought to me and I had to wait for the power to run out since the stem was removed. My next attempt will be to remove the barrel and barrel bridge and check that. Thank you so much for the response.
Welcome to the forum Chscott, and thank you for an informative introduction.
You have done exceedingly well so far in your horological journey, servicing the 7750 is no mean achievement. Regarding your current issue, that is excellent advice from Anil. it is never a good Idea to just partially service a watch, you should always completely strip it then you are starting with a clean slate and it is easier to locate problems by checking as each part is assembled.
When you have the complete train assembled, less click and balance, you should be able to drive the train by using your blower to puff air on the perimeter of the escape wheel. If this doesn't drive the train, there is something binding.
  • Similar Content
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
    • Hello, looking forward to participating on the forum here! I will mostly be listening and asking questions since I am an amateur hobbyist. I have most of the beginner hand tools and a Timegrapher. The extent of my tinkering consists of a successful Seiko 7S26 to NH36 movement swap inside an all original 1997 SKX007, along with a bunch of battery changes for friends and family. I have yet to tackle full disassembly and cleaning. Right now, I don't really have the budget or time to invest in a cleaning setup (even manual cleaning), but hopefully soon! I joined because I recently purchased a mechanical Timex Camper from 1994, and my searches for information regarding servicing and swapping out these Timex mechanical movements consistently led me to Watch Repair Talk. There is also a wealth of knowledge here about dial design, another area of interest for me. My other hobbies includes leather working (mostly small pieces, shoes eventually), crochet, sewing (would love to make clothing), design (especially type design), home espresso, cocktails, and tennis. I want to buy a film camera, but I don't need yet another expensive hobby involving last-century technology. Yes, I have ADHD.
    • HWGIKE#60 Accurist ETA 2390 Swiss lever, 21 jewels, full service A slim Accurist with a nice movement, eventless service, nice performance.
    • Hello and welcome from Leeds, England
