Hi if the timing problem is indeed the slip clutch, depending on the type ( flat spring) or(coil spring ) the movement will need stripping down. I have only had one clock with a clutch slip and that had a coil spring and the bush that supplied the pressure was slipping back on the shaft releasing the pressure. It        Regarding the lever and the cam they should come off after the pin and the screw have been removed. There have not been many I have had lever/pry off.  Try holding thr shaft and rotating the cam and lever a little.
On 7/8/2023 at 9:45 AM, nickelsilver said:
Sounds to me like the friction is too low, and it's slipping when trying to move levers.
Sorry I overlooked getting back to you after your first reply 😕 But yes, I think you’re right. And I’d say that the minute hand pipe is crimped on to the centre wheel arbor. I’ll try to get a close up photo tomorrow.
Good morning! I was a little more determined this time and was able to remove both with a firmer pull and twist.
Everything is cleaned and ready for reassembly now. I’m not able to remove mainsprings safely so that’s something for the future.
14 hours ago, oldhippy said:
The rack can you put a fine wire through the hole
Morning! Yes, the hole was clear and with a firm finger grip and twisting motion I was able to remove and clean the rack. Same for the chime stop plate. So all cleaned and ready for reassembly!
14 minutes ago, oldhippy said:
Did number 1 have a screw?
Yes, two screw between the two plates that stop the chimes :
Morning! I know the clutch mechanism in a Smiths Enfield but this is what I see on this movement … what do you think?
Hi   On the center wheel between the plates is the spring clutch whether it is a leaf spring or a coil I don’t fully remember I think is a leaf spring type. You will see better when it apart and be able to re tension it.
the bit shown is the center wheel shaft and canon pinion. When it’s in bits you can check both the pinion and the center wheel bushing for wear. On the other side of the plate on the center wheel is the spring clutch have a look at the drawings that I attached you will see it .
Hi again … the plates are back together but I’m able to get a photo of the centre wheel since the going barrel can be removed … I haven’t come across that before!
There are movements where you are able to remove the barrels without taking the movement apart. Garrard have it in there chiming movements. Elliott Westminster chime as well. Here are two more. the first is Perivale the second is a Smiths.
Edited by oldhippy
Hi from what I can see there is no spring therefore the drive is via the center cam (the one with the lobes) friction on the shaft by the canon pinion so now we are looking at either the canon pinion is slipping, the gearing has lost or damaged a tooth. even the center cam could be loose. all points to check.
Yes … I see that on the movement with the problem. On this one I was surprised that the mainspring arbor simply dropped out of the going barrel. Hasn’t happened with the arbors of the other 2 mainspring barrels … maybe they’re just a tighter fit.
That’s what it looks like to me. I’m almost at the point where I can put a minute hand on the movement and turn it to observe what happens. I’ll get back to you.
If you are not sure if they can be removed tap the barrel arbor with a small mallet from the backside of the plate a mallet will prevent marking the arbor.
Good advice thanks. I’ll have a look next time. I like to disassemble and reassemble a movement a few times until I’m confident with the way everything works.
Without the pallets fitted I can clearly see the going train run when I rotate the minute hand with my fingers. When I stop the going train using a finger, I can still rotate the minute hand and see the canon pinion slipping on the centre wheel arbor.
So the big question is …. how to increase that friction on the movement with the problem?  It looks to me that the minute hand pipe is crimped onto the centre wheel arbor.
Hi. You will have to increase the pinch on the canon pinion to get the friction so that as the center wheel rotates it moves the canon pinion.  The tension has to be enough to drive.  And there should be a gap between the center cam and the canon pinion when fully pressed home.  Remove the canon pinion and thread on a brass rod when adjusting the pinch so as not to damage the pinion.
So do you think they are separate components?  And any suggestions for removing the canon pinion?  I’ve got hand levers for removing watch hands. I don’t think I’ve got anything that could pull the pinion off 😕  It’s a job I’m reluctant to do without seeing someone else do it first 😉
The pinion should lift off ok but don’t try to remove the center cam un less the bearing hole is worn and the shaft wobbles about. The canon pinion will only need a nip up as it’s on a tapered shaft just be careful and not too heavy handed, that’s why we advocate fitting it on a brass rod for adjusting and re fitting after each adjustment so as not to over do it.
Thanks for this. The movement is in the case atm but I might have an opportunity to try this on Tuesday. If not I’ll have to wait until September time. I’m not going to be here over the summer. But at least I have a plan. Thanks for your help … I’ll keep you posted.
    • My profile photo is age 20, last century, but I still look exactly the same so I'm not sure it counts ¯\_(ツ)_/¯
    • Hello everyone my name is Tom and I and I am new to the forum and new to the hobby. I have always had an interest in mechanical watches and finally decided to pursue it. I’m going thru online trading and have purchased the basic tools to set up a work area. I’m really looking forward to learning and thank you in advance for all of your knowledge!
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
