A few questions about calipers/ micrometers.  Do you own both and use them for different tasks?  Do you prefer Vernier scale or digital? Is there a big difference in quality between manufacturers, if so what do you use?
Yes yes yes and yes 🙂
Is it time to answer sensibly yet ?
Callipers are fine for “rough “ work, micrometer is better for finer accuracy but for pivot and jewels you need something like a JKA feintaster. Different levels of accuracy and fine measurement.
Tom
Tom
Thanks for answering sensibly Tom, you took the words from my mouth. I will add that i do have a cheap digital vernier gauge that is very accurate ( maybe i was just lucky ) that i use to take a particular measurement from a balance staff.
5 minutes ago, RichardHarris123 said:
Yes.
Are you sure ? Its a risky idea you have there Richard 🙂
I'm no wimp, give it your best.
I think a digital caliper is accurate enough for most work. The only time I use my digital micrometer is when using the lathe. Somehow, the micrometer is easier (more ergonomic) to use when measuring things on the lathe.
I use Mitutoyo digital calipers for large stuff, where I don't mind being off +- a hundredth of a mm. When I need to split hundredths, it's a micrometer. I prefer non-digital ones as they are lighter and more compact, I find digitals cumbersome. Then there's an array of bench mics, with various shaped spindles and anvils, horizontal and vertical, and some indicating bench mics that will reliably measure to microns. Large mics for diameters up to 75mm, internal mics, I think there's at least a couple dozen around the shop haha. But a good caliper and regular 0-25mm mic covers most everything. Digital or vernier is a matter of choice.
Mitutoyo for digital calipers are by far the best on the market, mine are over 20 years old and run at least a couple years on a battery (I never turn them off), and check out spot-on on gage blocks like when they were new.
There's pro video on testing Mitutoyo concluding they're fine for hundredths. Feintaster is great for people like me who could never caliper a jewel without tiddly-winking it across the room...
I use the Bergeon (the one on the left) when on the bench and need a basic measurement.
I use the JKA (center) when measuring a staff (or wheel pivots, etc.) and willing to go to the extra effort of fetching it and opening it up.  It consumes bench space, so I use it only when its features are necessary.
I use the caliper on the right when working on my lathe.
I used a Mutitoyo digital caliper (not shown) for crystals, stems, crowns, etc.
BTW, I picked the Bergeon for $47 plus shipping and tax on ebay.  It was a steal.
Edited by LittleWatchShop
    • My profile photo is age 20, last century, but I still look exactly the same so I'm not sure it counts ¯\_(ツ)_/¯
    • Hello everyone my name is Tom and I and I am new to the forum and new to the hobby. I have always had an interest in mechanical watches and finally decided to pursue it. I’m going thru online trading and have purchased the basic tools to set up a work area. I’m really looking forward to learning and thank you in advance for all of your knowledge!
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
