2 mainspring in serial
hello
i have a question and was wondering how can 2 mainspring directly being conccted in serial ? the way i imagine it is when the first one finsh winding and tehn the second starts then the first one is going to get winded right ?
i am really confused i am would apprecaite it if someone can explain
best reagrsds
Are you thinking like the Longines 990/ Lemania 8810? That's a fairly unique movement. There are two barrels, of different size, geared together (the barrel teeth gear into each other). Both barrels also have hollow barrel arbors, with keyways, and there are wheels with arbors that traverse the barrel arbors and key in. So, when you wind, you are winding one of these keyed wheels (or the automatic works wind it). It winds the barrel arbor, which makes the barrel want to turn, and it does, and winds the other barrel up. The smaller of the barrels has a fixed mainspring, the larger has a slipping mainspring, so when the first barrel is fully wound, it continues to wind the second- and when that one is fully wound, the spring slips along the barrel wall like any other automatic watch. The wheel keyed into the second barrel is what drives the gear train of the watch.
It's a very clever design, and provides a very even power output for the duration of the running. The keyed in wheels make the barrels effectively motor barrels, as opposed to going barrels, which some feel has certain advantages. Of note, a motor barrel can be made to be a little more "stable" than a going barrel, like Hamilton's motor barrel design. In the case of the Longines/Lemania movement, the part that drives the gear train is the keyed in wheel, which rotates on its pivots like any normal wheel; this is more stable than the short bearing span of a barrel riding on its barrel arbor (going barrel), and probably does contribute to the longevity and stability of the watch. In most iterations this wheel rides in beryllium copper bushings, but in some cases (like Vianney Halter's use of this caliber) it's jewels. Either way the bearing surfaces are easily renewed in case of wear, unlike in a going barrel.
Aside from that caliber, most double barrel watches I can think of just have two barrels that are wound simultaneously and also simultaneously drive the center pinion.
    • On the link that I posted, ne of the watches has no crown and another has an a crown that is not square to the case. Does a broken crown signify that the movement may be quite corroded, hence the stem has broken,  and does the bent crown simply signify that the stem is bent? Unfortunately as the seller has a bid on the items, he is now reticent to prise the casebacks off in case he damages something. The seller did reply with this email though. Hi again Michael - brief descriptions; Oris x 2, dials and hands ok and they set ok and one I just wound and it has been running for a few of minutes as I write this response. Rocar, dial ok no crown. No name dial no good and can't pull crown out to set. Roma dial and hands ok, I think it is pin pallet movement. Unicorn, good dial and hands and plexiglass ok for age. All cases and plexiglasses show wear except as mentioned. I have no idea what movements are fitted or condition so please if you do consider bidding, please do so accordingly as I don't like to disappoint my customers - regards and thanks again for your interest - Jim
    • The incomplete Vertex DD is a new project to sort out.  The Seiko gen 1, is my favourite watch to wear and is my daily.
    • To be fair it was a beautiful 'bumper'.  But, there was some loose parts in the case.  Perhaps 'pig' was a bit excessive 😄.
    • Hello and welcome to the forum.   Enjoy
