Heuer Jacky Ickx Eb8420 Teardown
  • 6 months later...
  • 3 months later...
On 6/28/2019 at 12:47 PM, Amateur said:
Hi Delroyb
Any recollection and advise on how to put that Chrono pusher spring back?
Thank you I appreciate it.
J.B
Hi J.B.
You probably worked this out yourself already but what I did was not to set both ends of the spring right away.
Instead, I set one end, then fitted the bridge over the chrono levers, tightening the screws down halfway.
I then set the other end of the spring through the cut-out in the bridge while keeping the bridge in place by pressing down lightly on it with my fingers.
Once the spring was in place, I tightened the bridge down fully.
I managed to get it done without a hitch, but in the event the spring does slip off the lever, it will be held captive under the bridge.
    • I loved his explanation of a teardown 😅
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
