Rusted mainspring winder
7 hours ago, LEIGH356 said:
but the arbor's are completely stuck solid with rust
I don't quite understand. The arbors are attached to the handles with no moving parts. What are they stuck too?
Some photos would help us understand the situation better.
17 hours ago, LEIGH356 said:
arbor's are completely stuck solid with rust . I've had them in the US cleaner but without any luck
the problem is you have steel on steel and rust. You'll need to get a penetrating oil specifically for penetrating rusty screws bowls etc. and let it soak for why health possibly quite a long while the ultrasonic cleaning isn't going to do any good here unless maybe are using the penetrating oil.
Then yes they can rust the older set we have they weren't stuck together but all the arbors were slaves rusty which did require some minor cleaning so yes they will rust so penetrating oil will be your friend here preferably one designed for loosening screws etc.
Hi
Sorry for late reply , work commitments .
 My terminology may be wrong , this is a new hobby and I'm still leaning .
It's the arbor's that are stuck solid within the the main body of the winder .  Of the set of 17 only a few can be separated from the winder body . In the photo of the larger winder "11" the arbor will not budge and turns the entire innerworkings of the main body . The  smaller mainspring winder works as it should .
I'll try leaving them submerged in oil as suggested
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
