K&d Inverto Reference Site Update
tomcolson
All,
I've posted more reference material on kanddinverto.weebly.com.
One item that might be of particular interest is a better table of stumps than I've seen posted elsewhere. The table is posted at http://kanddinverto.weebly.com/inver...hure-1937.html. There's also a secret decoder ring for the table posted at http://kanddinverto.weebly.com/decod...of-stumps.html.
Other recent improvements include the addition of dates (or possible ranges of dates) to the various references and reorganized menus that should make things a little easier to find.
Regards,
Tom
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
