Miniature carriage clock
Stuart2
1 hour ago, HectorLooi said:
If you remove all the carbon steel components of the balance cook, you could soak it in alum. It will take a couple of days.
the screw is actually screwed into a steel regulator arm, so I'm guessing that wouldn't work in this case.  I'm fascinated by the idea though, I've never heard of alum before now.
4 hours ago, oldhippy said:
If there is nothing to grip. How are you going to cut a slot. From the photo I can't see if it is protruding or not.
well I was thinking I could cut a small slot across the broken screw and the piece that its stuck in.  So long as the screwdriver is narrow enough I'm hoping it might be able to turn the screw.  As a backup, I might simply try and drill another hole in the hairspring stud and just leave the broken screw where it is.
It is possible to cut a slot, but the screw is so thin, that I wonder what will cut that thin slot. Then, will the screw untighten by the force of that small screwdriver if it was so tighten that it broke off? If You pres the stud out, then it will be easier, as the screw will be not tighten any more.
The standard way is to drill a hole thru the screw with smaller drill bit, to press tapered broach in and try to unscrew, and as a backup - to drill with bigger drill bit and cut new thread for bigger screw
Have you tried knocking the stud out? That might loosen the screw. You could also try some penetrating lube. A screw slotting file I expect it will be too big. One thing I used to use was an old watch oilier finding a rough part and try to unscrew it that way, It never worked all the time but you might like to give it ago.
thanks guys.  I did manage to press the stud out.  The stud is quite a tight fit still, so might simply try to press another stud in, positioning the hairspring hole at a suitable depth, then just leave the old screw where it is.  No real need to remove the screw I guess.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
    • @steve1811uk close but no cigar 🙂 I don't smoke anyway. I checked in my stock of parts and that's the closest I got to your dimensions. Good luck in your search. @RichardHarris123 I have an accumulation of all sorts of odds and ends that I acquired as a result of buying up the tail ends of old watchmakers estates. Usually after all of the great stuff has been stripped out, which means that the sweepings off of the workshop floor can be had for peanuts, but if you have the patience, can often be found to contain gold (both literally and figuratively 🙂 ). These came to me through on of those purchases. I doubt that I will personally be able to make use of even 10% of my accumulated stock, but having it, and knowing what I have, means that I can at least pass bits on to those who can use it whenever possible.
    • Hi and thank-you for your suggestions, as per Mark's instructions I checked my browser "Safari" and spell check and grammar was not ticked. So all sorted. Thanks CJ
    • As an alternative, clear nail Polish, the advantage is you can have a manicure at the same time.
    • I use Grammarly. It works really well and If English is not your first language, you will also receive help with formulations. There is a free version that covers most of my needs. It installs as a plug-in and works with all browsers and word processors.
