Well hello there watch peeps, good morning, afternoon or evening.  I hope we are all well.  Onto the subject of a micromotor/ flexible drill shaft, dont think I've seen one mentioned before but i will have a search later. First of all does anybody use one ? . I'm thinking the applications may be a little limited for watch repair, mostly for polishing i would think. The overall construction even for a quality made tool is probably not going to lend itself to precision drilling, but maybe for general basic making of small holes etc 🤔 ( what do most of us use for drilling holes ie. In the making of small bespoke tool items ? A Dremel type tool ? ) . For polishing i can see a wider use, good range of speeds and small more handleable than a Dremel.  I have come across the Foredom brand, very popular but seems to come in two qualities. A blue labeled one ( not cheap ) made in USA and a red labeled one ( quite cheap has the foredom name stamped on the motor but may be a knock off ) not sure where made. Anyone have any experience with either of these or a suggestion of a different brand or alternative idea. TIA
I have this one (Grobet). I use it for polishing crystals, removing rust, adjusting endlinks, etc. I also got a T30 quickchange handpiece from Aliexpress, but I mistakenly ordered the 2.35mm collet version instead of the 3.0mm so I'm using the handpiece that came with the motor. So far for what I use it for I'm happy with it.
Thanks guy, the Grobet looks like a good quality tool. I'm  used to seeing that brand associated with swiss files.
31 minutes ago, watchweasol said:
Hi NEW. I like Guy use occasionally, I have two one a Maplin own make and a flexishaft one , not a must have tool but useful and handy mostly for circuit boards.
Thanks WW, its not something I'm desperate to have just yet but I'm sure i will need something like this sooner or later. The dremel i have is suffice for the time being.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
    • @steve1811uk close but no cigar 🙂 I don't smoke anyway. I checked in my stock of parts and that's the closest I got to your dimensions. Good luck in your search. @RichardHarris123 I have an accumulation of all sorts of odds and ends that I acquired as a result of buying up the tail ends of old watchmakers estates. Usually after all of the great stuff has been stripped out, which means that the sweepings off of the workshop floor can be had for peanuts, but if you have the patience, can often be found to contain gold (both literally and figuratively 🙂 ). These came to me through on of those purchases. I doubt that I will personally be able to make use of even 10% of my accumulated stock, but having it, and knowing what I have, means that I can at least pass bits on to those who can use it whenever possible.
    • Hi and thank-you for your suggestions, as per Mark's instructions I checked my browser "Safari" and spell check and grammar was not ticked. So all sorted. Thanks CJ
    • As an alternative, clear nail Polish, the advantage is you can have a manicure at the same time.
    • I use Grammarly. It works really well and If English is not your first language, you will also receive help with formulations. There is a free version that covers most of my needs. It installs as a plug-in and works with all browsers and word processors.
