Hello from Canada
evildani
    • $12.50 + $6.00 shipping I do enjoy collecting ladies watches.
    • What voltage are you feeding it?
    • Maybe you had a bad one H, the cheap blue one i use has been fine for nearly 3 years now. It demags enough to stop the tiniest of screws sticking to the carbon steel tweezers i use. If it were to fail at some point in the future i very  probably would go up a level of device just because.
    • Lot of “industrial “ de magnifiers on Aliexpress  https://www.aliexpress.com/item/1005004699640024.html?src=google&src=google&albch=shopping&acnt=708-803-3821&slnk=&plac=&mtctp=&albbt=Google_7_shopping&albagn=888888&isSmbAutoCall=false&needSmbHouyi=false&albcp=17858129175&albag=&trgt=&crea=en1005004699640024&netw=x&device=c&albpg=&albpd=en1005004699640024&gad_source=1&gclid=CjwKCAjwo6GyBhBwEiwAzQTmcxIEVpMt1vFIKQyfjVwT95zrBsOi5dt-GgFOmLamBcMcu4tO7CfaaxoChnEQAvD_BwE&gclsrc=aw.ds&aff_fcid=b7140f118e144db7876d074872aec9cb-1716029308364-08531-UneMJZVf&aff_fsk=UneMJZVf&aff_platform=aaf&sk=UneMJZVf&aff_trace_key=b7140f118e144db7876d074872aec9cb-1716029308364-08531-UneMJZVf&terminal_id=6b7c60e41b044cb39d1431f62cda0958&afSmartRedirect=y   a hard drive wiper/degauser would also be worth looking at.   Tom
    • Unfortunately yes! Magnetism can wreak havoc on a mechanical watch movement if the balance hairspring becomes magnetised. The cheap blue Chinese demagnetise-rs are useless if you feed them the wrong voltage (> 110 V), and even so, they don't work very well. The one I got when I was new worked so poorly that it drove me nuts. Eventually, I was lucky to get a Greiner Magnomatic for a little money. It's an amazing tool that can be trusted to do its job perfectly in seconds. A new one comes with a price tag of  £885 excluding tax and shipping, and if you think that's a bit steep (I believe most of us would) and can't find a used one I'd go with @Jon's recommendation.
