It started slowly, then suddenly
So, I didn't intend to go full into the deep end of watchmaking but here I am.
It started with a SNK809, then at some point I realized that at some point servicing inexpensive mechanical watches was more money then they cost new. So logically I should do it myself.
One thing led to another and I bought a pretty sound starter set of tools trying to balance cheap with good where I could
Then the other weekend I found a estate sale, not much of go on from the pictures they posted before hand but I could see a nice desk, L&R watch cleaning machine and a lathe.
I ended up buying all of it of a price far too low for any given part of it but I didn't ask questions I handed over the money as fast as I could.
Still going through all I got from that haul and getting the desk setup, and I figured it was high time to join a forum so I could bounce newbie questions off the more experienced.
So, here I am!
Thanks
-Chris
Congratulations on acknowledging your affliction. Doing so is the first step towards a cure.
Be aware that hanging around here will exasperate your condition despite the goodwill of those seeking to help.
Enjoy yourself!
16 hours ago, nickelsilver said:
Show the loot!
Agree! If there's one thing we like to look at more than watch and clock parts, it's tools.
Welcome Chris. You are in the right place to learn about your haul and how to use it. You have years of fun and frustration ahead of you!
Oh man, its weird seeing an active forum. Love it. Social media murdered forums.
Anyhow, onto pictures. well one to test if this method works since I don't seem to be able to preview
<img>http://digitaloutsider.org/chris/watch_stuff/image006.jpg</img>
oh, it looks like the admins decided posting pictures in this manner is disallowed
Edited by TitleSeventeen
posting pictures is hard
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
