So, I didn't intend to go full into the deep end of watchmaking but here I am.
It started with a SNK809, then at some point I realized that at some point servicing inexpensive mechanical watches was more money then they cost new. So logically I should do it myself.
One thing led to another and I bought a pretty sound starter set of tools trying to balance cheap with good where I could
Then the other weekend I found a estate sale, not much of go on from the pictures they posted before hand but I could see a nice desk, L&R watch cleaning machine and a lathe.
I ended up buying all of it of a price far too low for any given part of it but I didn't ask questions I handed over the money as fast as I could.
Still going through all I got from that haul and getting the desk setup, and I figured it was high time to join a forum so I could bounce newbie questions off the more experienced.
So, here I am!
Thanks
-Chris
Congratulations on acknowledging your affliction. Doing so is the first step towards a cure.
Be aware that hanging around here will exasperate your condition despite the goodwill of those seeking to help.
Enjoy yourself!
16 hours ago, nickelsilver said:
Show the loot!
Agree! If there's one thing we like to look at more than watch and clock parts, it's tools.
Welcome Chris. You are in the right place to learn about your haul and how to use it. You have years of fun and frustration ahead of you!
Oh man, its weird seeing an active forum. Love it. Social media murdered forums.
Anyhow, onto pictures. well one to test if this method works since I don't seem to be able to preview
<img>http://digitaloutsider.org/chris/watch_stuff/image006.jpg</img>
oh, it looks like the admins decided posting pictures in this manner is disallowed
Edited by TitleSeventeen
posting pictures is hard
    • I'm a newb who is a bit late to the party here. I've purchased a Horia movement holder clone. And I'm aware that the support pins for the SW500 chronograph jewels can be different sizes. I purchased 0.8mm pins with the holder. These were all that were available at the time. Will these be the right size? Can someone shed a little light on this for me please?
    • That looks fantastic! I'm obviously a little late to the party here. Can you tell me where you sourced the case that you used in this build?
    • If pivot shoulder almost touches the mainplate, you will see lower amplitude and free oscilation comes to stop quicker. Such touching can stop the watch. This caliber is based on FHF, I think. So some parts of a cheaper movement of same caliber might interchange.  Both observation point to pivot worn short, which support you suspect , "worn pivot".  The problem with pivots wear to this point is , though the watch runs, pivots can easily jump out of jewel holes in the event of shock, pivots are actually not touching the end stones.   Classic watch repair recommends staff replacement or elongating pivots. Non classic let's you flip the end stones to have the dome side of end stone facing the pivot end, this will somewhat or wholly  compensate for the wear.  Regs
    • This watch has a pin end mainspring. It's a blued steel spring and may be the original >100 year old part. As you can see, it is quite set. Can anyone suggest where I might be able to obtain such a spring today? Dimensions: Height: 140 Thickness: 010 Arbor diameter: 340 Barrel diameter 989 (1/100 mm)
    • Many thanks for your answers: 1. I will clean both of them without risk 🙂 2. Both of the rotate inside their setting but they don't seem to come out. I will clean the cock (and the hole jewels) and I will see if they want to go out. I don't intend to force the setting pushing it out by any means. I only hope I don't need the dismantle the whole cock into all its components...! 3. I won't touch it. Only clean. I don't want to take risk... Thanks again! Thanks for your anwer. Yes, I meant short. In fact there are 2 pictures where It can be seen that the balance almost touch the main plate. The balance only spin freely when I loosen the cock screw and also the bottom jewel setting. I cleaned the exterior jewels on the cock and on the main plate. But I can't take the interior settings. I uploaded 1 picture on this  My reply to your comments are below. Apologies as I Replied rather than quote...
