I wouldn't know a Rolex if it bit me, but It has that "Trench Watch" look to it.  I love the engraving on the back where it says "From Granddad to Steve".  It would be cool if that watch could talk and tell us all about where it came from (Granddad) and where it has been with Steve and whomever else after.
If I recall some history of the first trench watches, they were adapted from a ladies watch (pendant possibly) and didn't have the maker's name generally on them.  I think the Germans had the first ones, but that would have been in the late 1800's.  Didn't Rolex get founded around 1915, and if so, this could be a very early model.
 Rolex would have made chronograde version of this caliber, usually adjusts to several positions, I see picture of some adjusted to  8 positions .
A high grade movement can spend weeks on bench getting adjusted by a master watchmaker, thats partially what makes them expensive.  high precision gears, finely polished and all that goes into a Rolex is missing here in this caliber, its a low grade version,  unadjusted ,  perhaps even lower grade hairspring on this movement.
The difference is in quality.  I don't know who made this movement.
Even if you buy one that left the company adjusted sixty years ago, it s oscilator is likely to lack the poise it once had, when a pivot breaks not all repairmans can poise it as good as before.
Not a master appraiser here, I think about £ 50.
I kinda disagree somewhat, Rolex in the early days used cordebert movements which were very high quality for the time. In addition Dennison were the premium case makers. It is likely a good quality watch however because it has been made for a jewellery shop it would be worth much less than if it had Rolex on the dial. I am not a watch appraiser so could not put any sort of price on it.
Tom
Tom
So we should analyse its heart beat to see if its a chronograde or not.
@Nucejoesorry I don’t understand what you are saying?
Tom
Ah I get it now Joe, Rolex did not always sell chronometer grade watches, that I believe is relatively recent in their history. At the time this watch was created Rolex was essentially a micro brand buying pieces and assembling. I think they have become a vertically integrated manufacturer in the past 20 or so years, they have used both cortebert and ETA movements in the past. Obviously they modified/finished those to suit. Rolex is a marketing company that happens to make watches.
Tom
Tom
Tom
From some of the research I've made of Rolex i agree with you Tom. In their past not exactly the Billy big boll--ks of manufacturing.
16 minutes ago, RichardHarris123 said:
It sold for £293.
  Some nice history with it. Seems like a self bought officers trench watch passed down to his grandson half way through ww1. Possibly killed in action ?
Tom
I am sure I have seen pictures of this very same movement adjusted in 8 positions, so if this pocket watch carried a Rolex badge it would have been adjusted. Dennisson may have  ordered non adjusted type or didn't want adjusted stamped on it ( possibly to pay less import tax/ custom charges)
I guess Rolex owned this caliber and did manufactured it in several grades.
I thought adjusted was for the American Market.
Hi Joe,
thing is Rolex didn’t make movements before they moved to Switzerland, they bought movements from Switzerland and English cases from the Dennison case company who were reputed to be the very best cases. They moved in 1919 iirc. The inscription in the caseback is 1917 so prior to the move.
some of this is from the official Rolex site, they used a movement manufacturer in Bienne, I have seen information that they only started making their own movements in 2004 when they acquired the manufacturer they were using, Aegler I think.
Tom
3 hours ago, tomh207 said:
Hi Joe,
Tom
Thats correct Tom. They even used Aegler's factory to advertise their watches. Gruen also used the same print lol.
The question is ;  is this movement adjusted or unadjusted?
Thats where the real value ( the grade) of this movement is.
    • Now thats a real man's tool press 👍. I have one just like it in my back garden for when just CANT fix a watch . Its not something i have had to do yet, @Waggybut wouldn't any type of press be able to do this ? What about an adapted chain link  extractor work or a micrometer with some sleeve pushers made to slot over the ends. @Waggy Found something that could work Scott, comes with different size pins and pushers. Only bit that would need making is a round former to support the inside of the case, a piece of stout timber, bit of oak or mdf might do it. What i like about this one is the pin is pushed in, its in a sliding sleeve so it doesn't turn while its being driven. This has 4 pin sizes and 3 stumps as well so it will come in for other applications, the pins could be adapted to take other accessories from jewelling tools. I've just ordered one myself for some play time.
    • So I purchased this one based on my case number being listed. (Unless my case number is incorrect. The last digits are faint)
    • I have the same tool from AliExpress and get the same anxiety when when using it. But you have to admit it looks awesome on your tool shelf. Makes you look like a pro. 🤣 Looking at the photo of the Horotec tool, it looks equally flimsy. It probably comes from the same factory. I was thinking of using the pushers supplied with the tool and making a hand tool from a cranked jeweller's punch. I'll grind off the tip of the punch and drill a hole at the end to fit the pusher in. The cranked shank would be able to clear the watch case give a straight in-line axis to exert force to tap the pendant tube out. Should be robust enough to last several lifetimes. I wonder why nobody makes it. 🤔
    • It reminds me of Ukrainian eBay sellers of Russian watches. More often than not the listings include the phrase "Serviced by Master Watchmaker". Of course, they never are, and it should be expected. It's the most corrupt country in Europe, definitely on par with Russia. Today our tiny country (Sweden) sent them another $1 232 255 518 with no accountability whatsoever for how the money will be used.
    • Now that is taking it a bit far. You are going to need a bloody big workshop.
