Reducing centre wheel endshake on Seiko - what do these instructions mean ?
By Michalzeszen · Posted
Ah so it is an active system. Both holes are in use (hehehe). Interesting. -
Thanks again. I hope to be able to source a fly in the next few days, but if not I will get back to you. Dell - that is a really helpful offer. Repivoting would be well outside my comfort zone. I live in Essex - almost another country, but not quite!
I see now where the plate is worn which would cause the wheel to tilt. Depending on the movement and how much you want to put in to it the easy fix is a new plate. The other option I've done in the past is to insert a piece of metal where it's worn. Schneider Electric_iPF-iPRD_A9L08501.pdf
I've noticed that some things are shipped from my country as well. Unlikely you will use any of the drills under 0.4mm, 0.4 seems about right for most re-pivot work for average watch sizes. Besides 0.3mm and under are extremely fragile and I found near impossible to sharpen, the flutes are so shallow and it's difficult to determine where to start grinding in the cutting and clearance angles once you've broken them. The cheap ones with the coloured size indicator collars have worked for me, though these ones might be better quality, they are 3x the price of the others. You guys really have to pay through the nose for this stuff. It would be interesting to find out how much cheaper it would be for you, if we acted as a go between . -
Sorry for the confusion but I was referring to the stud staying in the hole in the barrel.
