avia 15 jewel AS1002
8 minutes ago, RichardHarris123 said:
Your welcome.  I general oiling one movement is the same as oiling other movements, unless it's something special.  Light oil for fast moving parts and heavier oil for slow moving parts.
thanks again. i have a list that i have used in the past. also been reading info on oil on here to get the latest info..
AS984 / 1002 is a nice basic sub-seconds time only manual wind movement so about as uncomplicated as it gets. You're highly unlikely to find a service manual for it but all you need to do is to follow a logical system of work, work slowly, don't force anything, and take pictures of every step of the strip down as reference for when you put it back together. Also make sure you let down the power before you start, and it's good practice to remove the balance cock and balance and put it somewhere safe at the start of the works, that way it's less likely to be damaged.
One thing to note (and I have just checked this on a 984 in my parts stash) is that both the crown wheel screw and the ratchet wheel screw are reverse (left hand) threaded, so turn clockwise to undo. Otherwise there should be no real surprises.
I have attached a copy of the BHI guide to lubrication which should be more than adequate for your movement and is a good starting point for most clocks and watches in the absence of anything more specific.
If you get stuck on anything just ask on here.
BTI-The_Practical_Lubrication_of_Clocks_and_Watches.pdf
Edited by Marc
typo, I think I may need new batteries in my keyboard :-)
Let me know how you get on! I have (I think) the same movement in a Timor WWW that's next in line on my bench. I think as Marc says, hopefully pretty straighforward. Have you folloed Mark's courses on watchfix.com? I think with the knowledge there, you should be good to go.
I have watched a quite a few of his videos. Also worked on Seiko auto's. Citizen & walthan. Not done any for a year or two. But when I have time. Would like to do more!
BTI-The_Practical_Lubrication_of_Clocks_and_Watches.pdfUnavailable
Thanks Marc. Very helpful.
    • Well Gentlemen and Ladies I think we should thank @Mark for his posts putting our minds to rest and the explanation of running the site which is done very well. As a resource for watch repairs for new and old I would rate it second to none, the casual banter and dissemination of information  top notch, let us ll enjoy working on here and helping others. Any one can PM me as Iam sure others as well if it has to off the “record” and Marks blessing on that.   We appreciate that Mark is a busy man and totally appreciate what he does for us all.    So from me THANK YOU MARK. from an old timer.
    • Hi it depends on the watch. The ones with the day date complications  dial dots are not really any good as you have difficulty getting the clearance between day date wheels a the dial.  Dial feet can be fitted no problem, there are several options, the cheapest is to mill out where the foot is and glue a new foot on. ( available fron Cousins UK ) mterialhouse . Or solder on a new foot, only problem with that is you need great care not to mark the dial. I use a DIY. Dial foot machine works no problem.
    • If everything is inside them, then once restored and keeping time the oris could be worth 20 -30 each, I've paid a lot more Oris date pointers in the past. Bought this last week for a quid at a carboot sale. A cute little Smiths made in England alarm clock. The alarm didn’t function properly because the movement wasn't fastened in. But it runs perfectly now, the previous made a bit of a mess of the dial but i still love it. For the Smiths lovers here's  a picture of the inside before i case it up again. Still with it the original Jewellers box.
    • The canon  pinion height must match the one you are removing, the physical size of the movement if it’s the same as the one removed should fit ok. The bogey hole is the height  to maintain clearance from the crystal
    • I’ve come across this sort of problem. The Bergeon universal winders aren’t always universal.    Options are: Track down a movement specific winder Hand wind it Buy a new mainspring - probably the best option in my view.    I’ve been thinking how to invent a winder that uses the actual barrel arbor. Haven’t done it yet…
