5 hours ago, Macavity said:
Thanks again for the input, everyone. After last night, I'm wondering if my issue might actually be the pallet fork. After reinstalling it and winding the watch, I still get clean, solid left to right movements as the pallet fork moves along the escape wheel, but I'm noticing a lot of up and down wobble in the fork as well. From my understanding, that's not supposed to be there, correct? The pictures of the movement are blurry and not very good, but the first pic is the fork as high as it can go, and the second pic is the fork as low as it could go after I gently nudged it with my tweezers. Could it be an issue with the pivots on the pallet fork? Or is there supposed to be a little bit of up and down play on the fork when it's secured in place under the pallet fork bridge?
Also, @JohnR725, thanks for the explanation about focusing on the point between the two balance arms to set the impulse jewel properly.
IMG-7604.thumb.JPG.66f4886a778b36bff57d63851c05d1ab.JPGIMG-7605.thumb.JPG.ae9104fa31198526773de904f6d9d18c.JPGIMG-7608.thumb.JPG.8576facff3169ce8da730c83c24801de.JPGIMG-7609.thumb.JPG.22817405374ee64f819d00112c6abfdd.JPG
Hey would you look at that ! The pivot is missing on the pallet fork wow 🙃
Maybe something mac needed to discover for himself 🙂
It certainly looks that way
18 minutes ago, Neverenoughwatches said:
I was actually trying to lead you to finding it yourself through inspection, but people got all frustrated and arsy about it.
Makes sense, I was getting confused because it still seems to “work” as it should, minus the up/down wobble.
Just checked Macvity's intro, new to watch repair and the forum. Somehow slipped through the net as nobody said hi , welcommed him, I just did and ask our welcomming commitee to welcome our new friend.
Perfectly understandable newbies to be  unfamiliar with terminlogy etc.
I only thought large  fonts should attract more attention.
Rgds
It is a useful exercise to understand how each element of the going train works with each other element while noting the tolerances allowed.  Sure, the pallet fork would flick back and forth but in some movements (not sure about this one) there is a bit of a valley where the pallet lower pivot sits, so the body could still find a place to sit. HOWEVER, it will still flop up and down and completely miss the roller jewel. You are learning...this is a good lesson!!  Don't give up.
Rgds
It did and it was funny, I definitely heard an echo as it ricocheted off Yorkshire's three peaks 😅.  Oh btw Mac hello, nice to meet you 🙄
This is why i enjoy John's input, he is a great teacher. You don't often get a straight answer with him ( because that doesn't necessarily help you learn )but all the clues are there for you to decipher. John guides you in the direction you need to go to find the problem yourself this way you are more likely to remember what you’ve learned. Keep at it , you will make a shed load of mistakes but suck it up, learn and you will get good with practice and experience.  Now onward and get this working again 👍
20 hours ago, Macavity said:
I have a 6498 clone arriving later this week and I’ll probably order another 6497 for spare parts as well, then I’ll have something to actually compare it to.
One other thing is I think you should do would be when you get your replacement movement. When there is no power on the movement rotate the balance wheel 180° let it go and see how many times it oscillates then you'll know in the future what is the number for your watch. Also take some time and look at the watch when it's running. Initially were so excited to rip this thing apart that we don't always pay attention to things. Look at the balance wheel look at how to oscillates look at the hairspring out opens and closes look at it looks flatter.. Then compare it to you other watch you can make comparisons. It's really hard to tell with one watch especially when your new what is good and what is bad. Now they have some experience what you're looking for you can look at the new watch and things should be hopefully little more visible of what you're looking at.
Thanks, I’ll definitely play around with the new movement before taking it apart so I have an idea of what behaviors I’m looking for. Thanks again for all your help and explanations, glad the mystery is finally solved.
Great tip John, that gives a bench mark for some intial factory performance.
3 hours ago, Tonym199 said:
Hi I have more of a question I have an issue where the balance  spring is stretched out of shape but the balance itself is ok  is there  any way to replace the spring
Another skill that needs to be learned is how to fix your hairspring. Of course the first step is identify what exactly is the problem know how you'd need to fix the hairspring. There are books that talk about this there's also some videos. Ideally you want to get a scrap balance wheel or two or three and practice bending your hairspring there it's a thing you need to practice every single day to be good.
In order for watch to keep time to balance wheel and hairspring have to be matched to a very very close tolerance. This means in the case of flash hairsprings every single hairspring was vibrated for the specific balance wheel with someone. So if you look at the parts list there is no hairspring balance complete only
The exception to this is an over coil hairspring. To get the over coil in the correct location it's easier to pre-make the Springs to exacting specifications. But this means the balance wheel now has to be matched hairspring. Severe looking at American pocket watches in their parts book you always see timing screws. This way you can match your balance wheel to your new hairspring.
Then here's a link to the video or one of the videos have the same person wrote like a lot of books and one of them at least one of them has an entire section on hairspring fixing. When you're watching the video I would get a practice balance wheel because he is really really experienced any makes everything looks so simple and if you don't practice well after outcome might not be quite what to expect
The Sep 1995 issue of the Horological Times has two articles on hairspring manipulation by Archie Perkins and Henry Fried. The October 1995 issue has the second part of Fried’s article.
My copy of Fried’s bench practices does not have the chapter on bent hairsprings which I believe these two issues reproduce.
Edited by JohnFrum
1 hour ago, Tonym199 said:
Thanks for the info but the spring is destroyed do you know how to replace the spring ex connect a spring to the balance wheel
The reason why we practice on practice watches is because their disposable.
Now you need a balance complete or steal a balance wheel out of another identical movement. You cannot replace the hairspring as a separate component.
Presumably you are thinking a simple transfer of a hairspring onto your balance, little chance of a match there, but not impossible.
In cases the piece on bench is rare or expensive then  " Can't be done"  is no longer acceptable and there are alternatives approaches.
1-Building a hairspring out of raw coil of the right CGS . there is also the question of springs grade for high grade oscilators.
2-Cutting an existing hairspring until  you get the desired beat out of the oscilator, once you did, it would need to be studded and often re-colletted.
Since your practing now, you wouldn't be trigerring world war III ,  if you just cut until the right beat is axhieved.
Prior to advent of ready made balance completes. repairers had to build balance completes out of balance, hairspring and other parts.
Rgds
Rgds
@Nucejoe I think you have posted about vibrating hairsprings.  What tool do you use?
Wish I had a luthy tool 😩.
Instal the hairspring on balance and in the movemet, check the rate on TG, if slow rate, reduce  the spring's active length( do not cut yet) ,   check the rate, inch towards the right beat for the movement ie; when it keeps accurate time.
For low or even regulair grade  time pieces , I do not recollet.
Time consuming but how many of us have a luthy tool?
Rgds
I also have bundles of balances, so when I come accross a hairspring, chances of not having to cut is good.
Having bundles of balances and hairspring incerases the chance of matching spring--balance.
It would be much better if you could get a electronics solution rather than the conventional tool because using it is a pain.
Of course you could just make your own if you didn't care about the fancy base. All you need is just the balance wheel a balance bridge like the very first image in this discussion how hard would that be to make?
Believe me...I have thought about this a number of times.  Seems like an easy thing to build, frankly.
Building an electronic one is intriguing...will noodle on that a bit.
One other thing that has been bouncing around in my head...can you vibrate a breguet hairspring?
Edited by LittleWatchShop
I have shaped overcoils by just copying another overcoil for balances of same caliber.
Vibrate the hairspring as a flat one first, leave some extra length  , then copy the "another"  overcoil . Technically debateable, but you find matching the balance with the spring you shaped  easy as you would with a factory made one, acceptable delta too.
I heard factory made ones are shape by individuals who do this all day.  Overcoil shaper.  ha ha.
If yes Google hairspring vibrating tools then look at the images and you'll notice that there is several people that have made vibrating tools. Including at least cool electric ones in one of them either he actually tells you exactly how we did it.
Then just building any sort of electronic vibrating tool might be more interesting and then the mechanical version. If you get a clock timing machine for instance they will measure beats per hour. Otherwise you could build something for that or get a witschi machine because they will do beats for our.
Then the traditionally the over coil hairspring us as I pointed out on multiple occasions are pretty vibrated because the coils actually come in their books that show there were coils there are literally hundreds of shapes for wherever had one. But copying an existing one would be a better way to go rather than reinventing the wheel. So you should build a do this
Not necessarily even leave extra length but vibrate the hairspring form the over coil and if necessary for timing that's what the timing screws are for. That's why when you buy premade ones you're supposed to match the balance wheel so that hairspring.
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
    • Yeah I have seen 44-56 documented for Elgin 18 size elsewhere. I have the style of gauge that's like a set of feeler gauges and I never noticed before today it is faintly stamped "Elgin". Pictured is the way I have been measuring. I am going to go to a larger jewel than the 42 that had been in there. I recently won an auction on a big set of Fitrite jewels all in the little bottles, to discover that the what's actually in the bottles bears no relation to the chart of sizes printed on the box. In most cases it seems to be all mixed so in fact I have about 24 little bottles and thousands of assorted jewels of all diameters and lengths, which is better than nothing. But since I don't have a micrometer with a table, measuring for the exact diameter will be a big job. Instead I will test a lot of them in the fork slot the same way I measure with the gauge. But this is still the next thing. I have to get the escapement to unlock first.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
