Introduction
Razz
Good day! I am just getting started in studying wristwatches while looking into my grandfather's Omega Constellation pie pan. I live in Tucson Arizona and am an avid golfer. I am particularly interested in vintage mechanical watches.
Hello and welcome to the forum   If you intend to work on the Omega  I should get some practice in on some cheap watches first (running ones)  that way if they dont work afterwards you know you made the problem. Once your skill levels are up to it then do the omega.  The watch.fix site do some selfpaced courses run by our administrator Mark Lovick which have proved popular and informative.
Thanks! I do have a couple of ETA calibers that I will practice on, including this crusty Bulova. I am nervous to work on the Omega (561 caliber) just because it was my Gramps'.DSCN5036.thumb.JPG.7718ff907d83da082ce5984d89a18d69.JPG
Edited by Razz
Figuring out how to post additional comments.
14 hours ago, oldhippy said:
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
I look forward to learning about mechanical watches and servicing!
    • You're right Rich, throwing money at something that is practically worthless. I've had i happen a few times, its  disappointing, but a lesson learned in checking everything out before you put in too much effort. I'm still tempted to look through a load of balances and wheels i have to see whats doable with the genuine staffs, I'm thinking the  wheel that it came with is not genuine, it's had it weight completely hacked down.
    • Ok thanks  it was just the brass cover next to the previous 3 keyless parts. Normally i wouldn't have expected that to be used to identify,  but I've searched American,  German and French part catalogs and coming up with nothing for the set lever,set spring and  yoke. I will have another look later today. There is another way but you would have to measure the stem very accurately.
    • The diameter of the dial side is 40mm, and the other side 36,5mm. Here is another picture
    • The chronometer on the dial might just be a brand name, looking back yes i was mislead by the mention of Remontoir inside the case. Still not sure why it says Ancre Remontoir which translates to anchor winder, i imagine that means lever winder which still suggests to me 2 winding springs. I'm sure i have that same watch with chronometer on the dial ,I've never ventured inside it. My missus looks after 90% of my watches , so i will get hold of that one and have a look inside. Haha no not a remontoire, looks very basic.  Good to see the keyless works, can you measure the plate size to cut down on the search for them. Can you lay out that brass bridge cover as well please next to the other 3 pieces.
    • That's true. It is not a chronometer. As a matter of fact, I got it with another timepiece which is e real one, and only that (not a watch). I add a few pictures of my Chronometer / watch. no indication of a brand ...
