Hi all,
I've so appreciated the help and advice I've gotten on my questions so far. I have run into another new problem on an Elgin 18s Grade 326 model 5 pocket watch. This is the one with the little "tower" on the top plate with a hole in the side the pallet fork enters to interact with the balance.
The bottom balance jewel, located on the bottom of the "tower" has come loose from its rubbed-in setting. I noticed when I oiled it that it was loose, and upon examination I found that the rubbed-in lip was flaking off in several places, so much so that with a little prodding just to see how loose it was it came right out. The jewel itself is in excellent condition with no damage.
I am woefully under-equipped to try to rub in a new jewel, and I suspect similarly so for boring out and replacing the jewel with a friction fit version. Would it be possible to simply fix the jewel into the setting with a bit of shellac around the outer edges? Since shellac is used to hold other high stress jewels in place (roller jewel, pallet fork) it would seem to have capable properties for this, but I haven't found much online about doing it.
Thanks!
 I buy big watch Lots ( scrap or in need of repair) , so actually have living evidences to learn from of mistakes made by previous watch destroyers attempts to glue or shellac jewels& end stones in place.
Even if it does work, it just isn't proper watch repair practice.
Rgds
Rgds
Thank you for the advice. I would love to have a couple grand to drop on a Seitz tool and setting reamers but that really just isn't the case right now. I guess I'll either see if my client is ok with waiting or try the shellac method.
It would be nice yes if we can all afford new tools but keep an eye open on eBay they come up used as long as you don't have the have the full big superset which you don't then they don't cost thousands of dollars.
12 hours ago, cortman said:
Elgin 18s Grade 326
You can go to the website below enter in your grade number and we can look up what Julian need. Then it's in a setting and you can push it out of where it is now as you replace the entire setting. You can also look up a cross reference of all the watches that should have the same jewel although you will have to measure the balance pivot size to make sure you get the right pivot size.
Then once you have a part number you look online and find  people selling the jewel. First one the whole sizes rather large and the third link they do give you a choice. Remember the whole needs to be a little bit bigger than the actual pivot.
http://www.elginwatchparts.com/
https://www.ebay.com/itm/374363322134
https://www.ofrei.com/page2073.html
Thank you very much for those insights. I measured the pivot as best I could with my cheap calipers and settled on a .15 hole size. I ordered replacement jewels and will report back how it turns out. Thanks again!
  • 4 weeks later...
I know it's only been a few weeks, but were you able to complete this repair? I am always interested in seeing how first-timers accomplish these types of repairs as I am preparing to attempt some similar ones.
The replacement jewel I ordered on eBay did not fit the diameter of the opening. It could move side to side easily even with the cap jewel installed. I'll probably be trying to return it.
After researching a bit more, I found that the top and bottom balance jewels are the same for this watch- which let me use a set from my parts movement. The jewels look correct, but when I tighten down the balance bridge now the balance wheel stops. So I need to adjust the depth somehow it appears.
  • 10 months later...
9 minutes ago, 54chevy said:
Curious if this got solved.  A little bit of watchmakers paper under the balance cock will give you the height needed to free up the balance staff in the jewels
Tin foil is a good option comes in different thicknesses,  paper can attract and absorb moisture being hygroscopic.
Oh dear, traditionally watch repair they recommend a thin slice of paper in particular watchmakers paper which is a thin tissue paper at least that's what you typically find. Then a course you have the next peculiar dilemma typically people using the end pieces of paper will put it either in front of the screw or behind the screw to tip the balance bridge as we had a discussion somewhere else versus using a thin sheet of foil across the entire bottom and raising the bridge up nice and parallel providing the bridge wasn't bent in the first place which generated the problem requiring the shim.
Was that a diplomatic way of avoiding expressing your view of using paper in a watch 😉. As we know paper is mostly made from wood pulp and wood loves moisture. My office at home used to be in a single skin brickwork outbuilding that was only heated adequately when i was in there  catching up on dreaded paperwork maybe once a week. It could get pretty cold in there with only background heat keeping it at 10 ° in winter, it was dryish though. Lots of stationary in there, paper, paperclip , staples etc. Only the staples that were holding paperwork together rusted
Actually typically I never use paper I prefer to bend the balance bridge. But as per some discussion somewhere in the universe apparently bending the balance bridge causes people to become unhappy but it does solve a problem and it works fine.
Then it does bring up a problem of a thin sliver of watch tissue paper under the balance bridge will be protected by metal on both sides with possibly only the ends exposed to a miniscule amount of air. Then depending upon the type of watch sealed to varying degrees so the amount of moisture getting into watch to screw up the paper should be almost nonexistent much more likely to start rusting the watch up
: real life could be better just to deal with the balance staff like you're supposed to do and not have little slivers of paper or foil or people gathered Jing the plates the raise up spots of metal none that should exist the balance staff should be the right length.
As with many things in life people take short cuts just to get the job done. Marvellous explanation btw that covered many different ways to skin a cat. Personally I'm a dog man, but i still wouldnt harm a 🙀
 So the next watch destroyer has to figure out why his new balance complete feels unhappy in this new geometry of a movement you created.
Frankens are always created by others , not us , nooo wasn't me 🙃
Rgds
Out of curiosity  since the watches I typically work on our vintage American pocket watches  where exactly are you going to get a new balance complete?  Then straightening up a balance bridge that's already been modified by others  are you suggesting I should not fix a problem?
No doubt you correct frankens.
Rgds
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
