Nothing special to report here but this Felsa feels kinda different than the other watches I have worked on.  Granted, I am an amateur with limited experience.
The open mainspring barrel was a surprise for what appears to be a higher-end movement--kinda EB8800 feel.  Frankly, I left it untouched.  It is my watch from my box-o-watches, and I was not in the mood for dealing with an odd mainspring configuration this evening.  Maybe next time.
The automatic wind mechanism was more integrated into the movement than the ETA movements I have worked on.
Lots of springs.  Ugh.  The click spring was the most unusual that I have seen. The plate screw shares the click...essence of Roskopf.  It is almost all back together now except for calendar works.  I will finish it tomorrow.
The Felsa 30 jewels version  is a true workhorse, better yet the  41 jewels variant, heres one in vintage Fortis Stratoliner ,
https://images.app.goo.gl/U3Rs5kJseUEZvhkj8
Rgds
Rgds
I see the link gives error,   Google will bring you images of the watch. " Vintage fortis Strstorliner "
The self winder module integrated in mainplate is unique, not to mention other details. Beautiful pinion leaves, etc.
I have a 30J Felsa 4000N. The auto winding is a bit unusual, but works well. I was impressed by the overall quality. It runs really well. You can buy them surprisingly cheaply. I thing they are an under estimated and great value movement.
I was going to ask about quality. On one hand some parts appears to have a bit beefy and engineered while others have that cheap stamped look about them.
Do we get to see the dial?
 I don't know about its hairspring quality, but major part of the rest is superior to ETA, jeweled winder rotor bushing and jeweled barrel arbour bushing,  in 30 and 41 jewel versions, excellent pinion leaves, day changer a bit lazy however.
  • 2 years later...
Hello - I know this is from over two years ago.  I have a Felsa 4009 and there are a couple of springs I have to put in but one of them I have no idea where it goes.  The Date Jumper spring and the Date Jumper where lose inside the case.  Any idea where they go?  Do they go by the keyless works?
Well, I looked back at my files to see what pictures I took and what I posted here is all I have.  Odd, because back then, I was taking lots of pictures.  Show us pictures of the springs and your current status and maybe we can figure it out.
I still have the watch.
Nucejoe - Yes I have the Felsa 4009 PDF.  In fact my watch says it's Felsa 4008/9 (that's how it is labled) and I have both (well I have a whole bunch of Felsa PDF).
Unfortunately, those documents do not show how springs go and/or where they go.  Most of them are pretty self explanatory (yoke spring for one is pretty easy to figure out), but the date jumper and the date jumper spring (2575 and 2576 in those PDF files) are shown there.
I finally found an image which help me figure out where it goes.  Not that it has helped me in trying to get them set there without one or the other (or both) taking flight.  The tension is so high that if you have the date jumper in and try to do the spring then the date jumper come lose and if you do it the other way then the spring wants to take flight.
The image shows the date jumper and the spring (this image is from ebay not mine) and you can see them below that plate which they call the Minute Work Cock.  Anyway, if anyone has any tips, clues, suggestions on how to do this without either of these parts wanting to take flight. Then I would be very grateful.
I guess I should add images of what I managed and what I tried.
1. I was able to set the Date Jumper and Spring without the day ring
2. I was able to also put the plate on top (see image).
However, I can't put the day wheel if I put the plate on there and if I don't the second the wheel touches the date jumper it just jumps.
Well after more tries that I even know I finally got it.
In the end what I did is place the Day Ring (Date indicator) then the Date Jumper and then the date spring.  However, I left the spring without tension allowing the long leg to be over the Date Jumper.  Then I put that lid on (Minute work cock) on top with screws loosely.  Once all that was in place I used the tip of my tweezers to move the long leg to put pressure on the Date Jumper.  That's the only way I could get it done.
I don't know if that's how you are supposed to do it but I am not sure how else to get it.  Here are some photos.  I'll test it tomorrow to see if it is working properly.  Images below.
    • Hello Gentleman, Anyone ever work on this watch before? I've been enjoying this hobby for a while now and have had some decent results.  Am progressing nicely to more and more complicated movements,  but man, for the life of me, I can not figure out how to remove this ETA 7750 from the ring around it.  I've successfully removed the movement and its holder from its outer carbon fiber case, but cannot remove it further. I've removed both pushers and the stem and it, frustratingly,  doesn't simply drop out when inverted.  It also doesn't rotate from side to side within the outer movement holder.. it is stuck fast.   I'm a little embarrassed honestly.   The red arrow points to a line in the movement holder, but it is seemingly one piece and not separable there. I guess they just needed to reduce some outer diameter there. The ends of the minute and chronograph hand extend over the minute marking ring so would that mean that that minute marking ring is part of the dial attached to the movement? I guess I'm asking where does the dial end? Any point in the right direction would be most welcome. I've never worked on this movement before and I am chomping at the bit to do so.  It represents the next challenge in my progression. But obviously cant start until I remove it safely and I'm stumped!
    • Donor movement received. Now waiting for a proper & calm time slot to perform the transplant.
    • Hi Joe, I mean the situation when the escapement can be unlocked when pallet fork is pressed as the guard pin to touch the guard roller. This will be possible if the guard pin is short or the depthing of the escapement is not deep enough. The pallet fork was replaced, but I don't think it was adjusted to work correctly with this movement.  Of course, if there is defect on the guard roller, it also can lead to such problem.
    • Hi everyone, I am new to watch repair and loving the whole process, even some of my fails…maybe. Right now I am looking at purchasing a press for fitting watch crystals, and I was wondering if any of you have had experience with the BMC model (seen in photo) and if you know whether the Robur press dies would fit, or, if not, what alternative dies might as I am having trouble sourcing original ones.   I know that the subject of crystal presses has been a well covered topic here, so I apologies for bringing it up again but I hadn’t found any past threads on this points. Any help on this would extremely helpful. Thanks! Joshua
    • Hi, I just wanted to share the unmistakable quality of a Rolex made in approx. 1990. Cleaned and serviced for a friend using appropriate oils and greases, with Epilame on the parts recommended by Rolex. New mainspring and upper setting and jewel for the minute Pinion (cracked jewel). Run in overnight and then worn on the wrist for a couple of hours to warm. Without any adjustment to the balance weights the watch ran at 0 SPD DU, all positions within +3 and -2. Vertical amplitude after 24 hours of 230 degrees minimum. Watch running at zero seconds per day on wrist when worn 24 hours. Serviced just once before 20 years ago. No need to buy the Microstella regulator tool, not this time anyway 🙂 No scratches or damage caused to screw heads and bridges. All seals replaced and waterproof tested to 60 metres. All good practice for when the time comes to service my own Grand Seiko.
