Mainspring winders at an unbelievable price
Paul80
Always on the lookout for low cost watch repair tools I stumbled across this listing
https://www.aliexpress.com/item/1005004628144533.html?spm=a2g0o.store_pc_allProduct.8148356.71.174f4787pUZBWU&pdp_npi=2%40dis!GBP!£36.29!£36.29!£36.29!!!!%402100bde716700878353065703e5863!12000029892500559!sh
A set of 10 mainspring winders with steel arbours for a mere £36.29 plus VAT and shipping, these have to be the cheapest set around, anyone tempted 😉
They are for specific calibers, the listing says -
3135/2892/2824/7750/2671/2000/8500-1/8500-2/C07111/2235/8200
So, for instance, ETA 2892, 2824, 7750, Miyota 8200, etc.
If you wanted to you could probably look up the specs for each movement to get the barrel ID,  and the wind direction.
Welp, I got the cheap set in the mail this week, and I also got 4 spare seiko 7009a movements for parts, so a good time to break some more mainsprings.
They aren't bi-directional although I initially thought they were.
As said above, they're definitely made for specific calibers, and the closest I could find for the 7009a barrel was the miyota 8200 set, which is honestly probably too small. There's another set where the winding barrel sat exactly on the mainspring barrel, not inside it, that might have worked, but it seemed like a recipe for disaster.
That said, I managed to obliterate one mainspring through my own inexperience and testing/practising. But the next mainspring I happily got wound up and back into the barrel.
Good enough for a hobbyist I'd say.
Edited by lexacat
Hi all, newbie here.
Could someone who has a set of "value" mainspring winders make a list of diameters and winding directions. Looking at the supplied handles, they all look like RH wind but some of the movements listed would require LH winders.
I work mainly on old Swiss movements as a hobby. I need to decide whether to buy a starter set or 2 or 3 individual Bergeon sizes  in RH and add as I go along.
Thanks all.
I went with the individual Bergeon components.  1 handle (works for both LH & RH), 1 winder per size (works for both LH & RH), and individual LH and RH arbors for sizes as needed.
The arbors are really the only thing that is truly LH and RH.  The winders and handles can work for either direction.  I've found that 95% of the watches I've worked on thus far (not too many but a good amount for a hobbyist) have all worked with either a 5, 6, or 7 size.  There are a few oddballs along the way where it required a certain size winder, but the arbor was either too big or too small, so I wound those by hand.  For the most part, I find getting individual components to be a much more affordable way of getting good winders without spending the outrageous amount of money it would require for a full set, of which I'm guessing several would never get used by a hobbyist.
Thanks all.
See the section in grey
https://bhi.co.uk/wp-content/uploads/2021/05/HJ-Mainspring-Winders.pdf
Coming back to this again.
Can you tell me if the arbor shafts are interchangeable with the barrel part.        Or, are the bores matched to the shaft diameter for each caliber. I am looking at the diameters of the barrels and, if the shafts were interchangeable, it would give a good selection of barrel/arbor combinations.
The bore diameter is matched to the shaft.
Overall quality is decent for the price.
Will still buy Bergeon winders as the need arise (have #1, #6, #7 so far) but this is a nice variety to have.
I originally bought this cheap set for the smaller arbors, to use with the #1 Bergeon drum. Usable but didn’t solve my problem with winding the 1104A mainsprings.
What is your go to source for buying the individual Bergeon tools.  I found the main Winder Handle as they refer to it, but can't seem to locate the individual winders
Cousins have them.
https://www.cousinsuk.com/category/mainspring-winders
https://www.cousinsuk.com/product/watch-bergeon-arbors-for-winders-by-size
Edited by SpringMangler
Both Cousins(UK) and Otto Frei (USA) have individual arbors and arbor+drums
https://www.ofrei.com/page1145.html
Edited by JohnFrum
On 12/4/2022 at 6:19 PM, aac58 said:
I recently watched this video about that same winder set. It's really affordable and looks quite good, if only I had the information about the diameter and wind direction of those units...
Sizes mm
Left to right top
2000 = 7.2    2671 = 7.1    2235 = 7.8    8200 = 9.8   8500 = 9.0
Left to right bottom
8500 = 9.3    3135 = 10    CO711 = 10.8   7750 = 12.0    2892 =  10.7
All Right Handed. Left as well if you use brass washers filed out to the same size. insert, then reverse
I purchased some brass washers and have spent some time filing out the innards to fit the outer size of each of the Chinese winders. I now have the facility to place 10 different size springs left or right. It would have been too long to wait whilst I purchased springs of each size. Total cost £6.69p.
Edited by rossjackson01
  • Like 5
  • 5 weeks later...
I see mention of the Bergeon #5, 6 and 7 being common mainspring winder sizes.  Does this budget 10 piece set cover those sizes?
I don't follow you on the brass washers.  Do you have a photo?
Here you go.
On the box above the holders are the washers I purchased. I filed them out to fit each individual wider and have inserted them on the winder.
more information
39 minutes ago, rossjackson01 said:
Here you go.
I like the cheat sheet.
You've still got me puzzled on the washers.  How do those let you do left handed?
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
