Always on the lookout for low cost watch repair tools I stumbled across this listing
https://www.aliexpress.com/item/1005004628144533.html?spm=a2g0o.store_pc_allProduct.8148356.71.174f4787pUZBWU&pdp_npi=2%40dis!GBP!£36.29!£36.29!£36.29!!!!%402100bde716700878353065703e5863!12000029892500559!sh
A set of 10 mainspring winders with steel arbours for a mere £36.29 plus VAT and shipping, these have to be the cheapest set around, anyone tempted 😉
Haha yeah I bought em. I've never had ms winders before so have nothing to compare them to. I'll update when they turn up and I get the chance to use them.
I recently watched this video about that same winder set. It's really affordable and looks quite good, if only I had the information about the diameter and wind direction of those units...
They are for specific calibers, the listing says -
3135/2892/2824/7750/2671/2000/8500-1/8500-2/C07111/2235/8200
So, for instance, ETA 2892, 2824, 7750, Miyota 8200, etc.
If you wanted to you could probably look up the specs for each movement to get the barrel ID,  and the wind direction.
Welp, I got the cheap set in the mail this week, and I also got 4 spare seiko 7009a movements for parts, so a good time to break some more mainsprings.
They aren't bi-directional although I initially thought they were.
As said above, they're definitely made for specific calibers, and the closest I could find for the 7009a barrel was the miyota 8200 set, which is honestly probably too small. There's another set where the winding barrel sat exactly on the mainspring barrel, not inside it, that might have worked, but it seemed like a recipe for disaster.
That said, I managed to obliterate one mainspring through my own inexperience and testing/practising. But the next mainspring I happily got wound up and back into the barrel.
Good enough for a hobbyist I'd say.
Edited by lexacat
Hi all, newbie here.
Could someone who has a set of "value" mainspring winders make a list of diameters and winding directions. Looking at the supplied handles, they all look like RH wind but some of the movements listed would require LH winders.
I work mainly on old Swiss movements as a hobby. I need to decide whether to buy a starter set or 2 or 3 individual Bergeon sizes  in RH and add as I go along.
Thanks all.
I went with the individual Bergeon components.  1 handle (works for both LH & RH), 1 winder per size (works for both LH & RH), and individual LH and RH arbors for sizes as needed.
The arbors are really the only thing that is truly LH and RH.  The winders and handles can work for either direction.  I've found that 95% of the watches I've worked on thus far (not too many but a good amount for a hobbyist) have all worked with either a 5, 6, or 7 size.  There are a few oddballs along the way where it required a certain size winder, but the arbor was either too big or too small, so I wound those by hand.  For the most part, I find getting individual components to be a much more affordable way of getting good winders without spending the outrageous amount of money it would require for a full set, of which I'm guessing several would never get used by a hobbyist.
Thanks all.
See the section in grey
https://bhi.co.uk/wp-content/uploads/2021/05/HJ-Mainspring-Winders.pdf
Coming back to this again.
Can you tell me if the arbor shafts are interchangeable with the barrel part.        Or, are the bores matched to the shaft diameter for each caliber. I am looking at the diameters of the barrels and, if the shafts were interchangeable, it would give a good selection of barrel/arbor combinations.
The bore diameter is matched to the shaft.
Overall quality is decent for the price.
Will still buy Bergeon winders as the need arise (have #1, #6, #7 so far) but this is a nice variety to have.
I originally bought this cheap set for the smaller arbors, to use with the #1 Bergeon drum. Usable but didn’t solve my problem with winding the 1104A mainsprings.
As John says, the cheap set definitely matches bores to shafts.
I've got a lathe in the shed, been contemplating making some left/right alternative winders for some of these. Mostly just to see if I can...
What is your go to source for buying the individual Bergeon tools.  I found the main Winder Handle as they refer to it, but can't seem to locate the individual winders
Cousins have them.
https://www.cousinsuk.com/category/mainspring-winders
https://www.cousinsuk.com/product/watch-bergeon-arbors-for-winders-by-size
Edited by SpringMangler
Both Cousins(UK) and Otto Frei (USA) have individual arbors and arbor+drums
https://www.ofrei.com/page1145.html
Edited by JohnFrum
Sizes mm
Left to right top
2000 = 7.2    2671 = 7.1    2235 = 7.8    8200 = 9.8   8500 = 9.0
Left to right bottom
8500 = 9.3    3135 = 10    CO711 = 10.8   7750 = 12.0    2892 =  10.7
All Right Handed. Left as well if you use brass washers filed out to the same size. insert, then reverse
I purchased some brass washers and have spent some time filing out the innards to fit the outer size of each of the Chinese winders. I now have the facility to place 10 different size springs left or right. It would have been too long to wait whilst I purchased springs of each size. Total cost £6.69p.
Edited by rossjackson01
  • Like 5
  • 5 weeks later...
On 4/1/2023 at 3:00 PM, kd8tzc said:
So when you look at the chart, what do they mean when they say Grey Set vs Red set?
The red set has 14 winders
Edited by Kalanag
I see mention of the Bergeon #5, 6 and 7 being common mainspring winder sizes.  Does this budget 10 piece set cover those sizes?
I don't follow you on the brass washers.  Do you have a photo?
Here you go.
On the box above the holders are the washers I purchased. I filed them out to fit each individual wider and have inserted them on the winder.
more information
39 minutes ago, rossjackson01 said:
Here you go.
I like the cheat sheet.
You've still got me puzzled on the washers.  How do those let you do left handed?
    • This is a screenshot of a video of it running. Not the best quality, though.
    • Depends what sizes of watches you mostly service . If you were to say pocket watches then you might benefit by wholly replacing the 9010 for 9020. As a rough guide hp500 is twice the viscosity of 9020 which is twice the viscosity of 9010 at 20°c.  So hp500 would give you a more mid-range oil between thin 9010 and HP1300, but as it happens hp750 is more mid- range than hp500, but is that more or less useful when oiling a train of wheels. After the barrel arbor the jump down in pivot size is around half, then after the centre wheel maybe more than half until the escapement. And pivot size isn't especially a deciding factor, as the torque and speed of a pivot would be more relevant when thinking about which oil to choose. So 750 might only be useful on a centre wheel and nothing else, and 500 might be better than 1300 for oiling the centre wheel but still comprises the rest of the train, where 9020 would be ok for the train but too thin for the centre wheel, leaving only 1300 for the oiling of it. You see the problem we're having here. What can be ok for one thing is less ok for another in a different way, damping down power compared to oil spread.  Maybe mixing a drop from two opposite range viscosity synthetic oils will give you some approximate thickness of an in-between . You want a short answer now ?  I tnink I'd go with the 9020. Now be prepared for a whole host of different answers. Then to go with this, watch manufacturers change their minds about which oils to use more times than actresses change their knickers.
    • So, working on watches and your karma at the same time: win-win situation!
    • @SteveF ,  Go on to Dr ranfft website,  Enter keywords Omega 26.5T3  ranfft .  There Dr ranfft  has listed all related calibers to this family, all which beat the same frequency,  any balance complete of this family fit your watch. This would only expenad your choice of balance complete.  Recolleting your hairspring is easy, but matching it with a balance of the family is challanging. Regs
