Hard steel cone bearings in the head. They had a lower grade headstock for a while that used bronze bearings there. Honestly not a big difference, and many extremely good machines used bronze bearings. But the "Hard" was the cream of their crop (until they went with angular contact ball bearings).
7 hours ago, markr said:
It's happy to see you.
Haha there is few words in nickelsilver's explaination that i could JUMP on, but I'm just not going there. I'm  assuming the hardened steel bearings are less likely to GRIND to a halt if not regularly SERVICED. Just a thought as I'm not experienced enough to understand this TOOL and would hate to spark a BONE of contention on the subject so i will quietly EJECT myself away from the discussion in HAND.
OK, I won the bid and got the Levin lathe bed along with a "Levin Hard" headstock.  Lord, where is the brake pedal?  I think my lathe purchases are done...oh please!  I need to start getting rid of the ones I will no longer use.
Edited by LittleWatchShop
I'll be curious if the head fits your other Levin bed, and if the tailstock lines up with both heads. In theory they should, but I have seen enough Levin stuff that wasn't interchangeable that it put me off them in spite of the high quality (except for their cross slides, being head and shoulders above all others I use Levin there).
Levin based their design on the WW or Webster Whitcomb 50mm center height lathe, made by the American Watch Tool Company (later Derbyshire). WW made all the heads and tails to a specific standard, to make sure they were all interchangeable. Other makers tried to do the same (I know Leinen succeeded). I have a hunch that certain eras of Levin lathe parts are interchangeable and then there might have been a shaky period and then who knows- though I would hope that the much later machines were better.
One of the most ball-breaking tasks I've done is hand scrape a set of Levin head/tail/bed that were all made at different times to match each other. It was a favor for a friend too, I think I got a bottle of something for it, haha.
This will certainly be enlightening. On my other lathes, the headstock and tailstock are serialized, so they were made together to match--even the bed is serialized.  As you noted, it appears that Levin does not do this...so...yeah, I am anxious.  I bought the ebay pair only because that was my only way to get the bed.  I plan to use the head/tail that I have on the newly acquired bed.
I have tested the head/tail on the bed that I have and they line up to the degree that I have been able to measure so far, so I am optimistic on the new bed.
Will probably put the HARD headstock back on ebay and just take what I can get.
How did you do this?
It's a basic process (hand scraping) that can generate very high precision; on its most basic level you can get a surface very, very flat, on average, and very well aligned, absolutely. It gets  really tricky when more than two surfaces need to make contact and be aligned at the same time, like a WW lathe bed, haha.
For this project one of the two (head/tail) was loose on the bed, the other tight. That's the angular sides' contact. I scraped the bed down to obtain good contact with the loose one (I don't remember which was which), then I scraped the tight one to have good contact with the bed. I made a reference flat that could contact the base of the head and tail (for blue spotting) and had another bed I modified so it could only contact one side of the angular ways to use as a tool as I was bringing the alignment in. It's hard to explain, but you can imagine that you get "one shot"- if you suddenly have full contact, but the (let's say tail here) is pointing away from the head, there's no easy way back.
Whoa! I didn't think *anyone* new how to do that anymore.  One of my early jobs was working for Sheldon Machine Corp, an old manufacturer of engine lathes. I worked close to a pair of old Polish guys, who hand scraped every lathe bed and croslide saddle that went through the factory.  They were amazing.
Maybe I should learn, but it looks both laborious and precise
Time consuming.  Unless you are those guys I worked with, who had been doing it for years and years.
The other thing I've thought about  trying is the three plate method to make a polishing plate. So far, I've resisted the urge 🙂
Edited by dadistic
Well, I have stepped in it. Bought two lathe beds. Will pick the one I like and resell the other.
Can you do hand scraping on curved surfaces, such as a rod, while preserving a consistent diameter?
I don't think so. How would you find the high spots?
Something like a lathe spindle would be precision ground (and probably lapped) between centers. Then, on machines with soft bearings, the spindle would be used as the marking master to blue the bearing, and it would indeed be hand scraped. Not in every case, but in many.
    • Hi All. I would appreciate some advice for a complete newbie on getting into watch servicing - nothing serious,  just as a fun project. I've got a thing for hand-wound watches and would like to bring an old watch (or two) back to life, so looking to learn to do a strip-clean-oil-assemble cycle.   I've toyed with this idea in the past (years ago) and picked up a couple candidates to learn on, but never found the time for them.  One is an old Ingersoll, swiss-made 17 jewels. It seems to wind and tick. Casing, dial, glass are in great shape, so looks like a good candidate to me for the first service. The other is a Benrus DR23. It winds and makes a few reluctant ticks, but then seems to stop. Casing looks like a complete gonner, and the dial is in pretty poor shape too. If the movement is not broken and just needs a service, I wonder if there's any possibility of getting a cheapo Chinese casing & dial to fit this movement in, or is it extremely unlikely to be the right size?   For a start, I want to strip & assemble a movement, perhaps a dozen times to build up the basic parts handling skills. I see that online advice is to buy a Chinese-made ST36 for this purpose. Can I just go at the Benrus or Ingersoll instead, or does it make more sense to get a cheap ST for this? Thank you.
    • Hi,  I have this vintage Navitimer 806 with a bezel that plays a little bit as shown in this video: https://imgur.com/a/2NjdiF0 How would you fix this? I don't see where a gasket would fit for instance. Also, it seems this issue happens sometimes with older Navitimers.  Thanks
    • This is a screenshot of a video of it running. Not the best quality, though.
    • Depends what sizes of watches you mostly service . If you were to say pocket watches then you might benefit by wholly replacing the 9010 for 9020. As a rough guide hp500 is twice the viscosity of 9020 which is twice the viscosity of 9010 at 20°c.  So hp500 would give you a more mid-range oil between thin 9010 and HP1300, but as it happens hp750 is more mid- range than hp500, but is that more or less useful when oiling a train of wheels. After the barrel arbor the jump down in pivot size is around half, then after the centre wheel maybe more than half until the escapement. And pivot size isn't especially a deciding factor, as the torque and speed of a pivot would be more relevant when thinking about which oil to choose. So 750 might only be useful on a centre wheel and nothing else, and 500 might be better than 1300 for oiling the centre wheel but still comprises the rest of the train, where 9020 would be ok for the train but too thin for the centre wheel, leaving only 1300 for the oiling of it. You see the problem we're having here. What can be ok for one thing is less ok for another in a different way, damping down power compared to oil spread.  Maybe mixing a drop from two opposite range viscosity synthetic oils will give you some approximate thickness of an in-between . You want a short answer now ?  I tnink I'd go with the 9020. Now be prepared for a whole host of different answers. Then to go with this, watch manufacturers change their minds about which oils to use more times than actresses change their knickers.
