Anybody print the barrel closer that's floating around the internet?
By Hawaiikook808 · Posted
You better use a flat grinding stone for this. Seitz provided a (rare) round one from Degussit. Frank
I have removed the stem and open the case. The Movement can't drop out but it can be rotate Anyone has idea THANK YOU
