G'Day from Oz
DavoH
Hi All,
Newbie watch person. I recently became interested in this fascinating hobby.
So much to learn and so many watches to play with. I am in awe of the miniature engineering that goes into them.
Am doing Mark's online course and have nearly finished, can't wait to get stuck into working on one.
Cheers,
Davo.
Hello and welcome to the forum.  I'm still pretty new myself, having only been in the hobby for about 6 months (4 months on the forum).  I'm still fascinated every time I service a movement.  The engineering, machining, and thought put into the design really captures me.  I finished up a service tonight on a gorgeous little ST 92 movement.  I picked up an old Swiss watch on eBay for $20 that I thought looked interesting.  I'm guessing it was one of the many victims of the quartz crisis and went out of business.  The movement was filthy, but cleaned up nice and is running strong now after a service and tightening up of the barrel arbor port.  That's really where I'm finding the most joy, brining back to life old non-runners, mainly from watch brands that have long since disappeared.  That being said, I'm a sucker for a good old Seiko and my collection of 60's and 70's Seiko's has grown dramatically since this hobby began!
Best of luck on your new journey.  You couldn't have found a better place to look for advice.  The group here has definitely provided me with some guidance a few times these past couple of months.
Looking forward to seeing your projects.
Edited by thor447
    • Either of those ideas might work. Did you try putting a thin layer of rodico on the cocktail and then push the screw through it. Afterwards, soak in one dip
    • I would use some binding wire around the part before heating it. It protects the steel from being burned. I know that sounds strange, as you're going to heat it with a blowtorch, but if a part is thin and delicate the steel can literally burn away before your eyes, which isn't funny if you've put hours into the job. I bought some tools steel from Cousins a few years ago which turned out not to be tool steel, because it couldn't be hardened or tempered. I wasn't impressed, as I had spent two hours making the part for it to be useless.
    • Hi that’s what was meant by animal glue “ a glue made from animal products”. Ie bone , skin and other animal residues.  There was a place at Huntington YORK who used to boil down the ingredients. It stunk.   We used it in pellet form in a sort of Bain Marie on a gas ring  it was very good, didn’t think it was around any more with the modern glues,
    • It's back to the drawing board I'm afraid. As pointed out, the Rodico trick is so fiddly and my pin vice jaws don't close in union. I tried but the screw is so small it's hard to grip the screw in the Rodico without it moving all over the place while trying to get it in the vice. I started to shake too much so gave up before the screw flew off somewhere never to be found again.  I'm now thinking that maybe I could bond the screw on the end of a bit of peg wood and then dissolve the adhesive afterward.  I just had another thought🤔 I have some really small PCB drill bits maybe I could drill a small hole in peg wood and push the screw in, as stated I only need to get the screw started.  Another idea 🤣 Magnetize the screwdriver to hold the screw 🤔
    • Yeah there is a spring under there. Hopefully now I can source a screw for the click and the bridges! Thanks for your help!
